2004 s40 Immobilizer help needed i beg you
Thisonekiddd
Year and Model: 2004. S40
Post by Thisonekiddd »
Long story short the key broke in the ignition i trusted the wrong person to do it and when o seen what was happening i immediately towed the car home. Now im stuck with a car that wont start and not enough money to pay the dealer.
Details: the ignition is compleatly cut apart, literally he used a hatchet!!!! Tumbler is half cut apart housing is busted and looks like a shit show the ignition swithch was cut off in this wack attempt to "push to start" with bypass the security. the whole thing is done. I have rewired the ignition switch in im 95% sure the right order i have the white box for the immobilizer and the coil around the ignition back in place now with the fob i should be able to put it the white box and this coil all close to one another and start it via the ignition switch. Sadly i cannot. All The dash lights all the exterior lights the radio all of it come on when the igniton switch is turned but no crank at all so i try and jump the starter???? Does not work is the answer the starter motor will spin but will not engage to crank the engine. Im in ut the snow is here and my car is on the street the city will take it if its there to long any help is much appreciated and if its something i can do myself it would be best thank you for reading my long ass story thank you for your time and advice and have a blessed day
