intermittent right front vibration
- Year and Model: V70 T5 2001
- Has thanked: 13 times
- Been thanked: 17 times
Re: intermittent right front vibration
If the vibration is due to a front axle it's been my experience you'll know it's the axle by the difference in vibration depending on throttle load and Chris had asked this question. It's also been my experience it's caused by the inner tripod joint and you can't tell if it's bad from the amount of play you can feel in the joint. It's also hard tell if it's coming from the left, right or both axles. The vibration under load is caused by small pitting in the inner joint cup and as the tripod bearings slide on the surface with the pitting it will pull the axle side to side so the vibration is more of a shudder. The vibration will be dependent on the throttle load and even the angle of the axle relative to the inner joint. Vibration will be worse under more load and at certain speeds and you should feel a difference when easing off the throttle when the vibration is occurring; if it's the axle inner joint(s) causing the problem. Clicking noises are typically associated with the outer CV joint going bad, vibration would be the inner joint.
- Year and Model: 2001 V70 T5
- Has thanked: 3 times
- Been thanked: 2 times
Much thanks. From your description and the clicking noises I hear when I rotate the wheel it almost has to be the inner tripod joint. I have bad hearing but I can hear that the sound isn't coming from the wheel area - bearing or CV joint. So by process of elimination ----.
Now to order one...
Now to order one...
2001 V70 T5, 195K. My seventh Volvo.
Yep, an easy job to R&R the original. Direct drop in, and the only hang up was getting the center bearing to line up. Fiddly little task. And the problems went away with the new part. Much thanks to all who offered advice.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 322 times
Excellent. I also had some play in the CV joints, since I buy used ones, even the slightest play can cause these annoying vibrations. Worth mentioning, the left drive shaft (shorter one) can sometimes be completely stuck inside the transmission and impossible to remove (even main dealers may not manage to). Aftermarket ones may come with a locking circlip inside the transmission larger than standard, once forced in it cannot be pulled out again. I really like to grease this clip for this reason. The right shaft - longer with carrier bearing doesn't have this circlip and it's easier to remove but annoying to replace anyway because of it's length - worth having a helper
much thanks and thanks for the heads up on the driver's side shaft - I plan to tackle that one this week end....
- Year and Model: 2004 XC70
Any update on this vibration? I have a similar vibration from my front left, trying to decide what to do first. I may buy a used axle to test. If I was sure that was the cause I would buy new, but I have no clicking/popping when turning, and the vibration does not worsen due to acceleration.
Sorry - yes, replacing the passenger (right) side ended the vibration. The rubber boots were split and there was some slack in the U joint. I believe that was where the vibration was coming from. It was an easy job, but follow the youtube instructions for removal exactly.
- oragex
I also went with used axles. For the 5 speed auto transmissions, all axles should be the same on Front wheel drive S60 V70, but I'm under the impression the XC70 with the AWD will have different axles, at least the long right one. I had to try 2-3 axles on each side before finding a good used one, my lesson is really wait to find one with zero play in both CV joints - no rotational play in either CV joints, no axial play in the CV joint near the wheel, no lateral play in the CV joint at the transmission (careful because some transmissions have play at their carrier bearing in side the transmission). But there's more to check when getting a used axle. Some are cheap chinese make (usually with thin flilmsly clamps), others have had the outer boot replaced the wrong way - when this boot is replaced, the CV joint is split open and a clip is being punched out - if this clip was not replaced with a new one, the axle will have vibrations. So it's really a hit and miss with the used axles, one needs to be able to bring them back at the junkyard if needed. I would not recommend buying them used off Ebay. Speaking of vibrations, it's worth checking the wheel balance at different shops. Not all shops balance properly the wheels, especially if the tire or wheel are older. Finally, vibrations under acceleration and/or going uphill can be also caused by worn control arms bushings.
I guess I really should just buy a new joint if it's going to take that much to find a good one. I do have play in the transmission carrier on the driver's side, indeed. I couldn't feel any play in my axle, but that doesn't mean it's not there. The steering wheel doesn't shake so I don't expect it to be a wheel balancing issue, but I will rotate that wheel to the back to be sure.oragex wrote: ↑Tue Jan 28, 2020 8:27 am I also went with used axles. For the 5 speed auto transmissions, all axles should be the same on Front wheel drive S60 V70, but I'm under the impression the XC70 with the AWD will have different axles, at least the long right one. I had to try 2-3 axles on each side before finding a good used one, my lesson is really wait to find one with zero play in both CV joints - no rotational play in either CV joints, no axial play in the CV joint near the wheel, no lateral play in the CV joint at the transmission (careful because some transmissions have play at their carrier bearing in side the transmission). But there's more to check when getting a used axle. Some are cheap chinese make (usually with thin flilmsly clamps), others have had the outer boot replaced the wrong way - when this boot is replaced, the CV joint is split open and a clip is being punched out - if this clip was not replaced with a new one, the axle will have vibrations. So it's really a hit and miss with the used axles, one needs to be able to bring them back at the junkyard if needed. I would not recommend buying them used off Ebay. Speaking of vibrations, it's worth checking the wheel balance at different shops. Not all shops balance properly the wheels, especially if the tire or wheel are older. Finally, vibrations under acceleration and/or going uphill can be also caused by worn control arms bushings.
I'm glad the PO found his issue.
It is worth it to get a new one - I got mine from O'reilly and it was almost the same price as rockauto. $150 for passenger / $100 for driver side
- 14 Replies
- 597 Views
Last post by oragex
- 425 Views
Last post by Georgeandkira
- 99 Views
Last post by Eddystone
