Driver's side heating pad diagnosis
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
None of them works ? If the fuse is correct, can well be a problem with the cabin temp sensor, located behind the small grid above the right temp knob. If this fails (usually after a car battery replacement), the CCM will no longer work properly, including the heated seats. Need only to replace the small sensor or swap the CCM - similar year, battery disconnected,
- 12 Replies
- 3999 Views
Last post by a3inverter
- 695 Views
Last post by 0202224
- 8766 Views
Last post by dcm0123
- 2839 Views
Last post by regent
- 5718 Views
