So I have upgraded my TPS with Sacer, as car was pulsating on idle. Forgot to match the voltages during the new TPS install. Can't do ETM sweep test as the "software unrecognized" - software on my TPS is probably too old. Checked both potentiometers - difference is 0.2° between both of them. Car drove way better (still pulsated a bit) for a month, then it started pulsating again, but a lot more than before. My question is, could the pulsating be the result of the not matched voltage during the install?
Also, I have to fill the gas tank very slowly otherwise the pump just shuts off and some petrol spills out. Car is Volvo s80 2001, 125kw.
TPS question
Arnexas
- Year and Model: 2001
Forgot to add, the short fuel trim is constantly flactuating on idle (sometimes 10% positive, sometimes 5% negative), but is 0% on high rpms. The front oxygen sensor reads about ~1, but the rear is constantly jumping between 0.1 - 0.8 on idle.
- 2084 Views
Last post by volvolugnut
- 1247 Views
Last post by jbkeene
- 2635 Views
Last post by doublebug
- 1378 Views
Last post by Gerhard7
- 1506 Views
Last post by precopster
