I am just wondering if replacing the air intake tube, (in case I named it wrong), the tube that runs from the MAF to the not a turbo.
Seems pretty straight forward? A couple hose clamps, a wire connection and a few vacuum lines.
Anything particular I need to know or look out for?
I sure hpe this solves the issue and I can get her smogged. Then I can get to the task of the timing belt and water pump!
'06 XC70 air intake tube
- jimpierce7
- Year and Model: 2006 XC70
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
Is your Check Engine Light on?
If so retrieve the codes, write 'em down THEN erase them to clear the light.
What happened with the original hose?
Replace it with one that matches the old one.
Leave no small hose or connection unattached.
- jimpierce7
Yes sir. I'm at this point after all that. Even took her in to be smoke tested to find my vacuum leak.Georgeandkira wrote: 13 Dec 2019, 05:37 Is your Check Engine Light on?
- Been thanked: 4071 times
Your 2006 XC is a turbo car, though.
The PCV system is a bit of bear to get to and get cleanly attached on a turbo car.
- jimpierce7
I have the intake tube off!! That back clamp on the turbo (not a turbo lol) was a bit tough to get to. Tomorrow I put the new one on and I can where a few vacuum leaks were including where the sensor (?) attaches to the tube. I need to get a couple new clamps and put it back together tomorrow.
- jimpierce7
as I understand all Volvos have a turbo? These just aren't listed as having one. Not sure why though.abscate wrote: 13 Dec 2019, 10:45 Your 2006 XC is a turbo car, though.
In the first two generations of the 850 V70 cars you could buy either turbo or Naturally aspirated (NA) engines .
Engine number ends with T for turbo, S for NA
All XC , R , and T5 models are turbos
Base models areNA but can be fully loaded with options to the near full luxury of the line; I have one of these
Georgeandkira
To jimpierce7:
Back in the early years of my 2002 I read somewhere (meaning I can't verify the facts) that 70% of V70 production was NA.
Whether or not V70's and XC-70's were bunched together effects that statistic.
- 1966 Views
Last post by Traki56
- 2661 Views
Last post by waynegarbo
- 791 Views
Last post by pgill
- 1250 Views
Last post by JexedM89
- 7373 Views
Last post by rspi
