Stupid Immobilizer see manual
Brokens40
Year and Model: 2005 s40
Post by Brokens40 »
:oops:
Hi, I have a 2005 s40 turbo AWD.
I bought it not running. Mistake. It has the immobilizer message. I can't get a scan tool or Vida to read the car. I tested the CAN system to the Cem. It reads 60 ohms. I can't remember from working on other can systems. .. should it be 120 ohms ? Can someone please test their system at the OBD plug with an ohm meter ?
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
Without DiCE, I do not think you can get some useful info from that car.
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Brokens40 wrote: 12 Dec 2019, 10:20 I can't remember from working on other can systems. .. should it be 120 ohms ?
CAN has two 120Ω, one at each end. 1/ ( 1/120Ω + 1/120Ω) = 60Ω.
Active
Past
Brokens40
Post by Brokens40 »
I do have Vida dice. i got the program working on a laptop on a VM... it recognizes the dice tool.... but will not read the car, it gives me the
"not possible to read out information....."
i'm trying to figure that out right now. i've installed the program with no internet on, firewalls down, ect....
anyone fix this issue ?
yagger
Post by yagger »
Lets try. ) Do you have a skype?
RickHaleParker
Brokens40 wrote: 26 Jan 2020, 19:13 i got the program working on a laptop on a VM... it recognizes the dice tool.... but will not read the car, it gives me the
Check your VM configuration and and make sure USB 2.X is installed in the VM.
Some VMs do not support USB 2.X by default, you need to add USB 2.X support to the configuration.
Active
Past
