I have the dreaded lava lamp syndrome. I have seen instructions for swapping a mirror from used vehicle, by separating the glass from the circuit board. But, I am sure I will screw it up. I don't see how I can remove the glass from the frame without gravely distorting the plastic.
I have a mirror unit from a salvage yard.
What will happen if ai simply swap the two units?
If this won't work, are there any other options?
Thanks
2001 S80 2.9
interior rear view mirror
- RickHaleParker
- Been thanked: 980 times
The Upper Electronics Module (UEM) is in the center rear view mirror. Transfer the old UEM to the new mirror.
Active
Past
Past
rb61
- Year and Model: 2001 s80
- Has thanked: 1 time
Thanks for responding. I think I found a company that will do the repair for 99.00 (see below).
2 questions:
Will the electronics in the vehicle function properly without the mirror connected?
Does the UEM consist of the complete circuit board is just one component on the board?
Thanks again
""We can repair your mirror for $99 plus shipping. You can place the order online and then just send the mirror to us. Ordering info is posted here, thanks. http://www.radar-mirror.com/Mirror_Repair_Order.html""
Regards,
Scott Wheeler
[email protected]
972-571-7427
2 questions:
Thanks again
Regards,
Scott Wheeler
[email protected]
972-571-7427
- 674 Views
Last post by Lucky_Seven
- 1219 Views
Last post by phils94850
- 1040 Views
Last post by jimmy57
- 860 Views
- 1726 Views
Last post by 2004VXC90
