98 XC BAD fuel mileage, need help
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
The engine in my car is fairly immaculate. Intake ports super clean, intake valves shiny, fairly new timing belt kit. I have put in new spark plugs, PCV sys, air filter, all vacuum lines, coolant tank, coolant (2x), complete fuel sys cleaner in tank. Yet my fuel mileage is 14/20 mpg city/hwy. That's what a late 90's Chevy Suburban gets. I understand my V70 has the AWD shaft, but the estimated mpg is 17/26. I called Robert 'DIY' Spinner (RobertDIY on YouTube). He said I should be getting at least 25 on the highway. He said it could be a dirty or broken MAF sensor. There was hair, fabric, and dirt on it. I got it really clean. What else could be affecting my fuel mileage?
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- Has thanked: 1611 times
- Been thanked: 4075 times
Its time for a compression test. If the engine is worn, or valves are leaking, efficiency suffers
Brakes can drag
Get a scanner and read your fuel trims, injection times, assess that stuff
How many miles are on the puppy?
Brakes can drag
- CIK7
About 145,5xx miles.abscate wrote: 13 Dec 2019, 10:49 Its time for a compression test. If the engine is worn, or valves are leaking, efficiency suffers
Brakes can drag
- June
- Has thanked: 523 times
- Been thanked: 261 times
Your car is not rated 17/26 mpg that is for a front wheel drive 2.4L equipped car. Here are some screenshots of the EPA gas mileage for the 2.4 FWD which is not your car and the 2.3 and 2.4 AWD of which one is your car. I owned a new 98 V70 XC 2.3L and it was no gas miser. That was never the point of the car. Also notice Premium fuel is stipulated as used by the EPA during testing. If you use regular and run heavy oil that alone will make the couple mpg difference from what you are getting and what the actual original mpg rating is. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
