Did you know? 🤔
2003 C70 A/C bypass
mlanski
Year and Model: 2003 C70
Has thanked: 0
Been thanked: 0
United States of America
mlanski
2003 C70 A/C bypass
Post by mlanski » Sat Dec 14, 2019 10:29 am
New member here.
I'm trying to bypass the A/C compressor on a 2003 C70 2.3l, until I can replace it in the summer. I used a DAYCO 5060490 / 6PK1245, and it fits great. When I started the car the alternator and coolant lights came on.
I read in one of the other threads on the site that if you change the direction of the rotation on the alternator, it won't charge. Is this the case for the C70 as well? Will bypassing the A/C compressor throw the coolant light on too?
Any other suggestions on how to do the bypass?
Thanks!
Has thanked: 256 times
Been thanked: 813 times
Trinidad & Tobago
Re: 2003 C70 A/C bypass
Post by abscate » Sun Dec 15, 2019 12:26 am
From 1999 on Volvo uses alternator pulleys with a clutch, so they only operate when turned one way. The alternator itself will make current either rotation , so a solid pulley would solve the bypass problem. I don’t think we’ve found one that fits here yet.
Rare insight flash....has anyone tried putting the -1998 solid pulley on a 1999- on for this trick?
The coolant light is something else
Link To Volvo Glossary
mlanski
Has thanked: 0
Been thanked: 0
mlanski
Post by mlanski » Sun Dec 15, 2019 11:17 am
Thanks for the advise !
Has thanked: 9 times
Been thanked: 159 times
Canada
Post by scot850 » Sun Dec 15, 2019 12:14 pm
Coolant light cable to the float probably got disconnected when working on the SERP belt. Lift the header tank carefully and check the cable has not been broken or disconnected at the connector under it.
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
mlanski
Has thanked: 0
Been thanked: 0
mlanski
Post by mlanski » Sun Dec 15, 2019 12:35 pm
Great idea Neil. Thanks
smacknab
Year and Model: 99 s70 NA Manual
Has thanked: 31 times
smacknab
Post by smacknab » Tue Dec 31, 2019 1:12 pm
Not sure if youre still looking for insight on this, but on my 99 s70 I removed the compressor and replaced it with a bracket and pulley setup. It cost me as much as a used ac compressor would cost, so I don't think I came out ahead. I don't know how different the c70 is, but I'd suggest fixing the AC or putting on a used compressor.
Not sure where you live, but I've had alot of window fogging issues with the cold and wet weather since removing the AC (some of that might be a heater core leak though).
Here is the link to my thread that I put the part numbers on and other member provided some helpful feedback.
viewtopic.php?f=1&t=91632
Trinidad & Tobago
Post by abscate » Tue Dec 31, 2019 2:48 pm
I’m pretty sure I’ve got a good 1999 compressor and I definitely have a core that is dead if you go the new route.
I almost went used on the last pass as I though I had only months of car life left....that was 70k miles ago
