Did you know? 🤔
2006 XC90 starting issue
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
mchestnut70
Year and Model: 2006 XC90
Has thanked: 0
Been thanked: 0
United States of America
mchestnut70
Post by mchestnut70 » Sat Dec 14, 2019 5:22 pm
I recently acquired this really nice 2006 XC90. My problem is when it's been sitting awhile or "cold" like in the morning or after work. I will start it, it will run at 500-800 rpm's for about 10-12 seconds & sputter out. If I hit the gas in that 10-12 seconds, it clogs out even faster. This goes on for anywhere from 9 to 25 repeats of this process. Then it will start perfectly, and run like a dream from there on out. It seems something needs to "warm up". It also seems fuel related and that's probably obvious, or not. That's why I'm here, as these things are built like a tank but I've read about all sorts of sensors n such & I'm rather baffled. Again it's why I'm here as I'm hoping to get some expert help/advice/opinions. My 1st Volvo & can handle basic stuff but by no means whatsoever a mechanic. Thanks in advance for any help!!
Mike
Has thanked: 0
Been thanked: 121 times
Re: 2006 XC90 starting issue
Post by cn90 » Sat Dec 14, 2019 5:38 pm
I think it'd be nice if people seeking help starts out with year/model/engine/FWD/AWD/trans/mileage info.
Something such as 1998 S70 GLT FWD auto 130K.
Right now, we don't even know your engine, mileage...
mchestnut70
Has thanked: 0
Been thanked: 0
mchestnut70
Post by mchestnut70 » Sat Dec 14, 2019 6:24 pm
Ok no problem. 2006 XC90 2.5T 177k. If any other info would help please let me know.
Thanks !!
Has thanked: 0
Post by cn90 » Sun Dec 15, 2019 9:57 am
Stalling during COLD start possible causes:
- Bad MAF (any CEL codes)
- Dirty Throttle Body (search for DIY I wrote a while back, very easy with a few bolts).
- How old are spark plugs?
- Air Filter
- Fuel Filter (DIY in forum)
- ECT near the thermostat. If your tstat is still original, time to get new Tstat+ECT (there is a simple way to replace these, I posted in forum).
mchestnut70
Has thanked: 0
Been thanked: 0
mchestnut70
Post by mchestnut70 » Sat Dec 21, 2019 5:49 pm
Thanks cn90 . I will check out your other posts.
Much appreciated !
Roger_850T
Year and Model: 854T 1995
Has thanked: 0
Been thanked: 12 times
Roger_850T
Post by Roger_850T » Sun Dec 22, 2019 7:34 pm
Do you have VIDA? Are any trouble codes being set?
Spark plugs are good to check, if you don't know when they were last replaced. Cold temperatures make the fuel less volatile, and harder to light off.
Possibly the temperature sensor that the ECU reads. It sounds like it dies with a transition from open loop to closed loop control, and with a bad input that might make it die until the engine has warmed up enough. (I'm guessing on this one, need to research more to be more confident.)
Check the fuel pressure at the rail. Probably not it, but free and easy to check, and good to rule things out.
Roger
'05 XC90 V8 140k
'95 854T 310k
'02 V70 159k
'03 S80 111k (crashed)
'93 945T 217k (gone to be parted out)
'87 245 300k+ sold, still going
'84 264 Diesel, RIP at 160k
'78 242 manual everything.
'73 P1800ES, fun until the rust set in...
