Portable 12 Volt Power Supply
Oka
Year and Model: XC70, 2001
Has thanked: 9 times
Been thanked: 4 times
Post by Oka »
Sometimes I need a 12V DC power supply. When no fully charged car battery is laying around, I would have to charge one up.
I just searched and found some. One thing, I would not want to spend too much on one. What portable power unit would one recommend?
Thanks.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
First question is how much current do you need? Very low current could be supplied by two 6 volt flashlight batteries in series. Or do you want to plug a 12 volt power converter into wall outlet?
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Go to amazon and search "battery portable charger for car".
They can be bought for $45+.
Has thanked: 1610 times
Been thanked: 4065 times
A small 12 volt power supply will be about 1/4 the cost of a 12 V charger, for 5-10 amps
Oka
Post by Oka »
volvolugnut wrote: 15 Dec 2019, 10:35 First question is how much current do you need? Very low current could be supplied by two 6 volt flashlight batteries in series. Or do you want to plug a 12 volt power converter into wall outlet?
Just like the car battery would - 12-Volts. The "12 Volt power converter" may be what I need than getting a portable rechargeable unit that would produce 12 Volts. Working on a car and need to test a relay with a 12V power source.
Oka
Post by Oka »
Oka wrote: 15 Dec 2019, 14:57
The AC to DC power converters I like has the cigarette lighter end adapter.
Just wondering. What if I connect a battery charger to a car battery as if am charging it, than tap from the battery connections?
Oka
Post by Oka »
cn90 wrote: 15 Dec 2019, 11:38 Go to amazon and search "battery portable charger for car".
A battery charger did not give me what I need. I have a Schumacher SE50 I connected to a car battery, tested the connections and it was 15+ volts. I connected my 600A heavy duty jumper to the battery, it was twelve volts at the connections. I used the later to do a test on a fuel pump relay. So, battery charger does not do what I need. My setup was clunky but at least for now, it worked. Would really need a unit from AC to DC (12V).
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
Oka
Post by Oka »
abscate wrote: 15 Dec 2019, 12:58 A small 12 volt power supply will be about 1/4 the cost of a 12 V charger, for 5-10 amps
The 12 volt power supply I have been seeing are with cigarette lighter end for the 12 volt output.
Post by cn90 »
I am confused.
The Schumacher SE50 does not provide what you need?
It is converting 120V AC to 12V DC.
Post by cn90 »
Or install a brand-new battery in the car and keep the old battery as a "tester".
Of course, charge the old battery once every 2 months or so.
