Hi,
My fuel door will not open on my 2000 Volvo V70XC. When I pull the release tab on the driver's side door, I just hear a click around the instrument cluster area. I have seen lots of posts where it can be released manually by pulling a tab/cable on an actuator.
I pulled off all the rear passenger trim on the car and cannot locate any actuator. I have also pulled off the trim that goes to the rear passenger side tail light assembly.
Does anyone know the EXACT location of the actuator (if it has one) on this particular model? If someone could attach an image that would be great!
Best,
Eric
Cannot open fuel door 2000 Volvo V70XC
- gmh
- Year and Model: 2016 XC60 T5
- Has thanked: 28 times
- Been thanked: 22 times
Hopefully this link will help:
viewtopic.php?f=1&t=82220&p=446142&hili ... or#p446142
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
1969 145S (1987-91)
1973 145E (1989-90)
Richard99
- Year and Model: 2000 V70XC
- Has thanked: 26 times
- Been thanked: 23 times
Thanks a bunch. I was able to locate it after some more searching. It’s hidden pretty well but once I found the torx screw it was easy to find.
Eric
Eric
Eric
1998 Volvo V70 - rear-ended and totaled
2000 Volvo V70XC
2007 Volvo V50 T5 AWD M66
2000 Volvo V70XC
Richard99
I was able to remove the actuator and followed SiRobbs video on cleaning and lubricating the unit, however this did not help. I recently ran a scan of the vehicle and received a couple faults from the VGLA (see attached pic). Any advice on where to go from here? It seems like the VGLA is not supplying enough voltage to the various components of the central locking system.
Eric
Eric
Eric
2000 Volvo V70XC
2000 Volvo V70XC
- 11 Replies
- 1977 Views
Last post by Marilyn99
- 955 Views
Last post by bigt8r
- 974 Views
Last post by Cees Klumper
- 1106 Views
Last post by Geno9707
- 1327 Views
Last post by Mauiman
