My speedometer displays values 15% higher than the real one (GPS°.
On my model (Volvo S70 T5 from 1998) the speed information transmitted to the speedometer don't comes come the sensor but from the ABS box.
It does not seem possible to correct this problem via software.
Also, I would like to have an answer on the following question: The information from the ABS box are they a variable frequency of square waves or a DC voltage.
In the first case, I could consider a frequency divider circuit, in the second, a simple voltage attenuator.
Thank you in advance for a lead allowing me to correct this annoying problem in our age of speed limits and cops everywhere.
Speed meter 15% too optimistic Topic is solved
- Has thanked: 311 times
- Been thanked: 817 times
Are your car's tires stock size for the vehicle? Check the tires and the label located on the rear facing side of the driver's door.
- Esperado
- Year and Model: 1998 S70 T5 Auto
- Has thanked: 5 times
- Been thanked: 4 times
Thanks for your answer.
My tires are standard, but, anyway that is not the subject. My car is how it is.
The question is a technical question: What is the standard of the information transmitted by the ABS module to the speedometer. Square waves with variable frequency, or DC with variable voltage ?
My Volvo garage is unable to answer this question or to tune my speedo, and the OBDII command for the tires circumference (60) do not seem to work neither.
Whatever the cause of this problem, I would like to correct-it.
- Stu70
- Year and Model: 2006 Sonic VR GT
- Has thanked: 34 times
- Been thanked: 26 times
From the wiring diagram - it might be just a generic symbol - but it looks like a square wave signal.
I don’t a graphic meter or oscilloscope to measure for you. But I would think it’s more likely a variable frequency square wave pulse summed directly from the abs sensors.
1998 S70 10v BiFuel - Sold
2006 Sonic V70R - “this is going to be expensive “
- Esperado
Thanks a lot, Stu70.
I have found the following on the CPU schematic:
#B18 Signal speed (from combined instrument panel)
U ≈ Ulowor Ubat (the voltage depends on the position of the front wheels)
f increases with speed f = 40 Hz at 20 km/
But I don't think it is the one used, as, on the ABS schematic,
On the pin 6 of the connector, I see a cable Y-BN with what I suppose it is a connector 24/13C that goes to the A3 input of the dashboard to the speedometer. But no indication of the standard ;-(
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
My TEVES manual says for the MK20 module it's a duty cycle ground, so it would be variable frequency square wave. That's assuming your 98 is the same as a US spec 98 and has the MK20
But....In my opinion your energy and money might be better spent figuring out why it's off vs a workaround. I've never seen an MK20 have a speed reading going to the cluster that is outside spec with the proper sized tires on the car.
That's the first time I've ever opened that manual up since I bought it 9 years ago.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- Esperado
Hi Matty Moo,Matty Moo wrote: 16 Dec 2019, 18:08 But....In my opinion your energy and money might be better spent figuring out why it's off vs a workaround. I've never seen an MK20 have a speed reading going to the cluster that is outside spec with the proper sized tires on the car
Thanks for your care.
My tires are standard 205/50/16, and the speedometer/odometer/cruise control are working fine apart this 15% constant error. And I have re-soldered inspected/verified my ABS module pins and welds.
As i'm an electronic engineer, it should not be a huge work to interpose a frequency divider in order to have a more accurate reading. This 15% error really bores me. But It would help me a lot to figure out the frequencies range. I don't have a portable scope/frequency-meter and it should be complicated to drive with a wire connected to my house
[edit] I found a simpler solution: https://www.brickboard.com/RWD/volvo/85 ... meter.html
Cool, hopefully the only thing broken is internal to the speedo, like the resistor you are probably looking to replace. So something doesn't just create another problem in a little while.
Very interested to hear how you adjust the reading, please post up if you figure it out! Pics always welcome ...
- Esperado
Here is the schematic of the integrated circuit with is part of the speedo that transform the frequency into DC voltage proportional to the speed that move the voltmeter (speedo).
http://www.radioradar.net/en/files.html?fid=489248
On pin 4 is the resistance that have to be adjusted. As it is 100 Ohms by default, I think I will put an adjustable of 200 Ohms with a shielded wire in order to have-it accessible from outside. Then, the car on a flat highway in strait line (under cruise control at the legal max speed) according to a GPS I will adjust-the speedo. There is an electrolytic cap on the 12V, here, that I will change in the same time. They don't like age.
That is the correct way, but, as I'm lazy to unmount my dashboard, I will try before; from outside, to add an adjustable regulator in order to decrease the 12V to 10.2V and see if it works.
Attached the general schematic with the 12V line in red.
- befarrer
- Year and Model: 1998 V70 AWD
- Been thanked: 24 times
I'll just add in here that my 98 V70 AWD speedometer is also greatly optimistic, it's roughly 10-15% fast. I have P195/65R15 tires installed, the odometer however reads slightly low, maybe 5% slow?
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
05 VW Golf TDI
- 696 Views
Last post by davidfisser
- 2509 Views
Last post by Volvo Kush
- 1531 Views
Last post by mod64
- 8920 Views
Last post by rhubarb
- 954 Views
Last post by MoVolvos
