Fast ATF leak
bluebertone
- Year and Model: 2001 Volvo xc70
2001 Volvo xc70, 130k, transmission rebuilt (previous owner) around 90k. Sudden fast leak of fluid, seeing mostly on ground passenger side near tire and from the top just under and to the right of power steering fluid reservoir (not using ATF in power steering). Still have a tiny bit of fluid on the dipstick. I have very little experience w transmission issues, especially on these cars (surprise!) so, what should I investigate first?:) it’s unfortunately 20 miles from the nearest Volvo mechanic, so I’m also trying to determine if it will eventually need a tow. Thanks, everyone!
highmiles
- Year and Model: 2001 S60 T5
- Been thanked: 4 times
That seems like an odd place for a transmission to leak to as the transmission itself is on the driver's side. If it is the transmission, the two seals that can be replaced without removing the transmission are the left and right driveshaft seal. The other seal would be the input shaft seal, that would require pulling the transmission, it is located behind the torque converter. I have had a major leak there before and would find a huge puddle right below the transmission even after driving around the block.
I would check and top up all the fluids and then keep an eye on them.
bluebertone
Thank you!
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
ATF passes through the radiator to be cooled. You could have a hose clamp or radiator failure. I'd check every connection to the radiator and look at the radiator for cracks.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
bluebertone
Yes, this makes sense- thank you!
- E Showell
Or hose failure, of course. If your radiator is the original, it may be past its "sell by" date.
'95 855 auto (sold)
'95 855 auto (sold)
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Have you lifted the power steering reservoir to see ? Common leaks at the hoses. If you also lift the coolant reservoir (these are usually stuck together), disconnect first the electrical plug for the coolant reservoir level sensor (don't pull on the wire)
bluebertone
I'm always nervous I'm going to break that plastic piece but I'll lift the power steering reservoir this afternoon when this damn rain stops:) will let you know what I figure out- thanks so much!
- oragex
Some simply break off the small upper plastic hook already, makes it easier to remove - it's also secured with two 'sliding' tabs at the bottom. If the hoses leak, I rather cut off the last inch of the hose, then tighten back (need to empty the reservoir). The cap may also be leaking
If the reservoir is fine, may look at the p/s hardline that goes near the right wheel along the subframe, where the engine mount sits: this line may get crushed and cracked at this point (there's also an EGR line passing by)
- 11 Replies
- 11754 Views
Last post by STSCowboy
- 19 Replies
- 5138 Views
Last post by erikv11
- 2246 Views
- 1528 Views
Last post by MoVolvos
- 1525 Views
Last post by Turbo_Boss
