Inspired by SM in the middle of his V70 NA head gasket/valve job
I did a quick search in the Forum and found people reporting success with three products for the cam cover sealer.
Volvo sealant 1161059 1160158 about $40 per tube
(see photo attached)
Permeatex product xxxxxx
Loctite Part 515 518 - differences?
Quick request - can you gurus add knowledge to this thread ?
Issue at hand is SM is stuck in 15F now, perhaps 32F later - we want to know setup time for the sealer as function of temperature
P80 Cylinder head cover 1161059 1161058 - anaerobic Sealant, Sealers, primer and install temperature
I found a recommendation to use Locite Primer N764 for application below "Room Temperature"
Second column, Fifth Paragraph, titled COLD CURE
Loctite-18005-Gasket-Sealant-Data-Sheet.pdf- (16.06 KiB) Downloaded 212 times
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
I had this as an issue once and I put two 150 heat bulbs shining on head and threw a furniture pad/quilt over the hood to form a tent (use a prop for hood as support cylinders will go down) and let it sit overnight and started the engine the next morning. That car has never had a leak or seepage.
- smacknab
- Has thanked: 97 times
- Been thanked: 43 times
Ah good idea, I'll try that with my small space heater tomorrow after I set it!
07 V50 T5 AWD M66 ~146k miles
- 2759 Views
Last post by BlackBart
- 12 Replies
- 6929 Views
Last post by erikv11
- 402 Views
Last post by lrock
- 1079 Views
Last post by Sveedy
- 3132 Views
Last post by MadeInJapan
