I'll be performing maintenance on the server March 31. I'll try my best to make interruptions as painless as possible. Thanks for your understanding.
Did you know? 🤔
2001 C70 Whistling - Fixing Passenger Window Seal?
Nigel
Year and Model: 2001 C70 Convertible
Has thanked: 1 time
Been thanked: 0
United States of America
Nigel
Post by Nigel » Fri Dec 20, 2019 7:35 pm
Hello all. I have a 2001 C70 which experiences whistling at speeds around 60mph (or during high wind) on the passenger side front window. I've narrowed it down to the window seal - it whistles when the window is up and not when the window is down. Is there anyway to refurbish the window seal, or is a complete replacement necessary? Thanks!
Stu70
Year and Model: 1998 S70 10v
Has thanked: 14 times
Been thanked: 14 times
New Zealand
Stu70
Re: 2001 C70 Whistling - Fixing Passenger Window Seal?
Post by Stu70 » Fri Dec 20, 2019 11:09 pm
Check the door lifter mechanism, where the green rollers are... You remove the door card, door pull assembly, and the black foam covering the access hole behind it. You may have to lower the window a touch to see the rollers. The front roller should have a bendy piece of copper coloured metal in the roller Chanel under the roller. This slows the front roller causing the the glass to tilt towards the back as it raises, jamming it firmly into the recess. Also check the rollers while your there. I Had the same thing - whistling window- and wouldn’t have noticed that the steel wasn’t there had I not happened to see it lying in the bottom of the door. It has prongs that locate it in the chanel and shouldn’t move much.
New part
Springy steel thing
Access hole- note missing spring thing
These users thanked the author Stu70 for the post:
Nigel
1998 S70 10v BiFuel “it’s a what??”
Last of three factory fitted CNG Press Cars :roll:
Nigel
Has thanked: 1 time
Been thanked: 0
Nigel
Post by Nigel » Tue Dec 24, 2019 9:12 pm
I appreciate the in-depth response. I'll give this a shot
