IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
2003 V70 t5 build
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
Vwagonguy
Year and Model: 2003 v70 t5
Has thanked: 0
Been thanked: 0
United States of America
Vwagonguy
2003 V70 t5 build
Post by Vwagonguy » Sat Dec 21, 2019 11:58 am
Okay so I’m 100 percent new to the Volvo game. I know very little other than what my close friend has shown or gone over with me. I just recently purchased a 2003 v70 t5. The head needs to be redone or replaced. I was wondering if anyone could throw some info on if the 2.4 or 2.5 heads will fit on a 2.3 since they’re the same except bore size. Or if I just need to send mine off to be ported polished and resurfaced. Thankyou!
RickHaleParker
Has thanked: 3 times
Been thanked: 545 times
RickHaleParker
Re: 2003 V70 t5 build
Post by RickHaleParker » Sat Dec 21, 2019 11:12 pm
They are not all the same except bore. The combustion chambers have different volumes. That is how they get different compression ratios with the same stroke and bore.
Best to stick with the correct head unless you do detailed research on both engines and crunch the numbers.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
SuperHerman
Has thanked: 0
Been thanked: 157 times
SuperHerman
Post by SuperHerman » Sat Dec 21, 2019 11:40 pm
There is nothing magical about Volvo heads, except you NEVER mix and match heads and the cam cover. They are MARRIED!
RickHaleParker is a great source of information on what can be interchanged - I defer to him 100%.
If you are doing the work, pull the heads and see what is wrong. You may be able to simply clean and service your current head and valves. As you will most likely be buying an head gasket set, do your valve stem seals and lap the valves if the shop is not doing them. Were it me, I would pull the head and see what the issue is (after a leak down test to make sure there is actually a problem). If all looks good I would have the head machined flat ($100), and then change the valve stem seals and lap the valves myself. Again, nothing magical about the Volvo heads - it takes time, but it normal head work. If you are going to farm out the valve job you need not worry about this part.
Supergrunged
Year and Model: 2005 S60R
Been thanked: 2 times
Supergrunged
Post by Supergrunged » Sun Dec 22, 2019 2:55 pm
What exactly is wrong with the head? Only thing that ever goes on the head is the valve seals, or burnt valves. Which a burnt valve will show a cylinder with low compression if you did a compression test.
Swapping heads is not going to gain you anything without a tune. Honestly, you really need the head done, yes, replace your valve seals, valves as needed, port and polish, and send it. Otherwise, start looking at your upgraded intercooler, downpipe, turbo you want to throw on, and who you want to tune it.
