2009 xc90 3.2 r design awd slight antifreeze smell in cabin
chefmarkt69
Year and Model: 2009 XC90
Post by chefmarkt69 »
Hello, I have been wondering as of this winter when I turned the heat on. I smelled a very slight smell of antifreeze in the cabin of the car. The heat works great, I checked my anti freeze level and it was low. I add more antifreeze but I do not see any leaking on the ground. I put down cardboard box on the ground to double check but still none.Does anyone know what this might be? Thank you
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Could be a leaking heater core. Does the inside of the windshield fog up easily or have a residue on it? It does not take much of a leak so you most likely will not find antifreeze in the floor well.
Active
Past
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
As above, look with a flash light under the dash, drv side, look where the two alu pipes are entering the heater, perhaps the two o-rings are leaking
chefmarkt69
Thank you both, I did not see and residue and or leaking fluid.
chefmarkt69
It doesn’t do it all the time, like this week I have not had to add any antifreeze.
oragex
Post by oragex »
Have a look at the water pump. These are known to fail on the 3.2. The pump has a hole to check for leaks. Use onlu quality brands if replacing it - such as Aisin. May replace the thermostat while there. For the antifreeze, I recommend Volvo concentrate+distilled water. Also look under the coolant tank, see if there are traces - disconnect the level sensor before lifting it. May also look at the top of the radiator for any leaks
