Trying to removal the serpentine belt of 2009 s60. I have done these on 2005 and lower but not on a 2009. Don't see where to put the tool in for the tensioner, Is there a plastic cover on the tensioner?
If so how do it get the cover off
Thanks Madness
removal of sepentine belt 2009 s60
volvomadness
- Year and Model: v70 2003
- Been thanked: 9 times
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
If there's a black plastic cover, put against its side a long flat screw driver then give it a small smack with your fist (I've simply used a long piece of pipe), it should jump off & no need to put it back. If you're going for the hex bolt, you need a ratchet slim enough to fit by the car frame. For the tension, you'll need a long handle, an extendable ratchet is the best - also toss the power steering reservoir - if you also lift the coolant reservoir, undo first the electrical connector underneath or it may damage the level sensor
- RickHaleParker
- Been thanked: 980 times
OR
Active
Past
Past
- 1125 Views
Last post by Marauder 1
- 5229 Views
Last post by Soloracer
- 20 Replies
- 17909 Views
Last post by Hurtfeelings
- 867 Views
Last post by mark636
- 2338 Views
Last post by cn90
