Did you know? 🤔
removal of sepentine belt 2009 s60
2001 - 2007 XC-70
volvomadness
Year and Model: v70 2003
Has thanked: 0
Been thanked: 3 times
volvomadness
Post by volvomadness » Mon Dec 23, 2019 4:45 pm
Trying to removal the serpentine belt of 2009 s60. I have done these on 2005 and lower but not on a 2009. Don't see where to put the tool in for the tensioner, Is there a plastic cover on the tensioner?
If so how do it get the cover off
Thanks Madness
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 50 times
United States of America
vtl
Re: removal of sepentine belt 2009 s60
Post by vtl » Mon Dec 23, 2019 5:18 pm
It can be either torx hole or the hex nut on the bearing. I've had both types of tensioners.
05 XC70 260k, 16 XC60 40k, 19 Tundra 1k
oragex
Year and Model: S60 2003
Has thanked: 92 times
Been thanked: 233 times
Canada
oragex
Post by oragex » Mon Dec 23, 2019 6:41 pm
If there's a black plastic cover, put against its side a long flat screw driver then give it a small smack with your fist (I've simply used a long piece of pipe), it should jump off & no need to put it back. If you're going for the hex bolt, you need a ratchet slim enough to fit by the car frame. For the tension, you'll need a long handle, an extendable ratchet is the best - also toss the power steering reservoir - if you also lift the coolant reservoir, undo first the electrical connector underneath or it may damage the level sensor
RickHaleParker
Been thanked: 448 times
RickHaleParker
Post by RickHaleParker » Mon Dec 23, 2019 10:34 pm
OR
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0,
Plant Torslanda Sweden.
