Hello
My car: Volvo S60 2003 200HP Turbo
In Volvo Vida I get «ECM 3000 Inlet camshaft sensor - signal missing»
I’ve changed the camshaft sensor but it didnt fix the problem. Its the sensor behind the engine on the drivers side?
If I clear the fault codes, it comes back again.
The «check engine» light comes on after I have started the car the third time after clearing the codes. The car cranks a few seconds before it starts. The 3 wires from the connector looks fine. Changed the vvt solenoid, plugs and battery.
Any suggestion what to do?
Camshaft sensor no signal
- RickHaleParker
- Been thanked: 977 times
Double click on the DTC and read the DTC description.
Active
Past
Past
- RickHaleParker
Red and black are power and ground, blue or blue-black is data. One cannot read data with a Multimeter.MaximusNO wrote: 28 Dec 2019, 23:07 1 Red/white, 2 black and 3 blue/black. What should the data be on each wire/pin when you test it with a multimeter with key in position II?
Use the resistance function to check for shorts between any of the three wires on the harness side.
Use the resistance function to check for opens along the length of any of the three wires on the harness side.
If you double click on ECN-3000 or search for ECM-3000 this is what you will find in VIDA.
ECM-3000 Camshaft position (CMP) sensor, intake.
Diagnostic trouble code (DTC) information
D2800350 Condition
Diagnostic trouble code (DTC) ECM-3000 covers the intake camshaft position (CMP) sensor on 6 cylinder engines and the exhaust camshaft position (CMP) sensor on 5 cylinder engines.
Diagnostic trouble code (DTC) ECM-3010 covers the exhaust camshaft position (CMP) sensor on 6 cylinder engines.
Diagnostic trouble code (DTC) is stored ECM-3000 or ECM-3010 is stored if the pulse width modulation signal from the camshaft position (CMP) sensor is constantly high (signal too high) or low (signal too low).
Diagnostic trouble code (DTC) ECM-3000 or ECM-3010 is stored if the pulse width modulation signal from the camshaft position (CMP) sensor is missing but returns sporadically (missing signal).
Diagnostic trouble code (DTC) ECM-3000 or ECM-3010 is stored if the pulse width modulation signal from the camshaft position (CMP) sensor is sporadically missing (faulty signal).
The fault is diagnosed by the control module when the engine is running.
Possible source
Signal too high:
- Open-circuit in the signal cable
Short-circuit to supply voltage in the signal cable
Short-circuit to ground in the power cable
Open-circuit in the ground lead
Defective camshaft position (CMP) sensor.
- Short-circuit to ground in the signal cable
Open-circuit in the power cable
Loose connections.
- The camshaft position (CMP) sensor is in the wrong position
Loose connections.
Loose connections.
The engine is difficult to start.
Active
Past
Past
- 996 Views
Last post by grackel
- 228 Views
Last post by perhss70
- 2599 Views
Last post by Luzanov345
- 2528 Views
Last post by Labone
- 8887 Views
Last post by rhubarb
