Hello!
Trying to figure out a coolant leak. From what I’m observing, the coolant leak is external and my car has no issues with overheating. I have seen the coolant overflow in the overflow tank, the coolant will expand and come out the overflow reservoir. I’m not sure where the extra pressure is coming from. I’ve replaced the thermostat 3 times and the tank once. I’ve relieved pressure a few different occasions, with the heat on full blast and what not but I’m still coming across this issue. Any ideas?
Thank you!
Coolant leak
- June
- Has thanked: 523 times
- Been thanked: 261 times
Perform a combustion gas test. You probably have a bad head gasket. Apparently the P1 cars are prone to head gasket failure. Just went through it with a 2007 C70. In our C70 the gasket failed in a way that allowed pressure to enter the cooling system, but no coolant into the cylinder or oil. Same high pressure pushing coolant out of the tank symptoms you described affected our car. It's a simple test and you'll find out for sure. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
iGuessImCool
- Year and Model: 2009 C30
Hey June, what was the condition of your head gasket when you replaced it?
- June
It was just a minor breach I think #3 cylinder. The pressure from the engine running could pass, but the coolant pressure was not enough to pass the other direction. In time it would have completely blown according to the mechanic. Both the head and block checked good without warping. Apparently this is not uncommon for these cars. Ours is a low mileage dealer maintained car. The dealer fixed it at a high cost. I'll look at the ticket and see if he mentions the cylinder that had the problem. The mechanic said it was the usual place they go. I completely trust him as he worked on my mother's cars before I was a teenager at that same Volvo dealership, that's over 40 years ago. June
My Volvo cars owned
1996 960 ordered
1996 960 ordered
- 16 Replies
- 4474 Views
Last post by granite
- 16 Replies
- 5381 Views
Last post by lcc014
- 1635 Views
Last post by DanSC
- 4128 Views
Last post by SuperHerman
- 4501 Views
Last post by rspi
