Did you know? 🤔
97 850 dash/headlights flickering only at startup. UPDATED
Peevarino
Year and Model: 2009 XC70, 97 855R
Has thanked: 26 times
Been thanked: 3 times
United States of America
Peevarino
Re: 97 850 dash/headlights flickering only at startup. UPDATED
Post by Peevarino » Sat Jan 18, 2020 4:54 pm
UPDATE!
It’s been doing the flickering a bit more often, but still only at idle, looked over a few other things, the battery to starter wire isn’t as bad as I thought once I removed a bit of the heat shrink.
Wondering if the PO had routed the serp belt the old way (less contact on alt pulley), I had a closer look. It’s routed the updated way, but when I checked tension, I realized it didn’t really have any, except I guess under load. I could move the tensioner pulley fore and aft a bit more than is probably acceptable.
So, I’ll be putting a new tensioner and belt (might as well, right?) as soon as time and shipping allows, assuming there aren’t two perfect examples at the pullapart tomorrow.
Will it solve the flickering? I hope so, but it seems like the car needs it anyway.
09 XC70 3.2
97 855R
misha
Has thanked: 49 times
Been thanked: 112 times
Serbia
misha
Post by misha » Sat Jan 18, 2020 6:01 pm
It could be that voltage regulator brushes are worn out.
Diodes should be checked too and alternator tested by a specialized shop.
About serpentine belt tensioner....you shouldn't be able to move it by hand.
'91 Citroen XM 2.0 SI /fully equipped/mandarine red metallic
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Peevarino
Peevarino
Post by Peevarino » Sat Jan 18, 2020 6:22 pm
I’ll be pulling a couple voltage regulators out tomorrow, as well, I seem to recall a couple newer looking alternators in the few P80 cars at the yard.
09 XC70 3.2
97 855R
misha
Serbia
misha
Post by misha » Sun Jan 19, 2020 3:53 am
The easiest thing is to try with replacement tensioner.
If that doesn't cure it....than attack the alternator.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Peevarino
Peevarino
Post by Peevarino » Sun Jan 19, 2020 7:19 am
That’s the plan, tensioner needs replacing anyway. If the alternators’ brushes look good at the junkyard, I’m going to get them, cheap backups just in case.
I really wish I had gone to the junkyard yesterday, though, it’s almost 30 degrees colder today.
09 XC70 3.2
97 855R
Peevarino
Peevarino
Post by Peevarino » Sun Jan 19, 2020 3:18 pm
Found a properly working tensioner and pulley at the junkyard, along with a nearly new Volvo stickered Bosch alternator. The PO put in a O’Reilly reman alt at some point, so I figured get it when I can.
No time left to put tensioner in today, family time and grocery run take priority now.
I’ll report back once the tensioner is in, I may have time on my lunch break tomorrow, assuming it’s not raining.
09 XC70 3.2
97 855R
