Did you know? 🤔
S70 Engine
Has thanked: 81 times
Been thanked: 245 times
United States of America
Re: S70 Engine
Post by erikv11 » Wed Jan 01, 2020 12:00 pm
I see you did a bunch of head work, did that include new valve stem seals? If not that could be another source of oil consumption. Also is a contributing factor to burnt valves.
(a) run as is adding oil
or
(b) replace the engine. Don't put in one with badly leaking valve stem seals. Also swap over all timing parts, replace cam seals, rear main seal.
These users thanked the author erikv11 for the post:
Thomas and Judith Lilli
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 285k
'06 S60 R, 165k
'99 Camry V6 :shock: 125k
E Showell
Year and Model: V70R '06 AWD Auto
Has thanked: 9 times
Been thanked: 55 times
E Showell
Re: S70 Engine
Post by E Showell » Wed Jan 01, 2020 4:15 pm
I speak Steve, that's Ph. D. for "almost."
These users thanked the author E Showell for the post:
'99 V70 NA FWD Auto, dark blue (actively for sale)
'06 V70 R AWD Auto, Sonic Blue Metallic
'04 XC70 Ruby Red Metallic
Has thanked: 274 times
Been thanked: 853 times
Trinidad & Tobago
Re: S70 Engine
Post by abscate » Wed Jan 01, 2020 5:39 pm
:lol: corrected above
Link To Volvo Glossary
Year and Model: 99 S70
Been thanked: 0
Re: S70 Engine
Post by Thomas and Judith Lilli » Tue Jan 07, 2020 3:04 am
Yes, the head was professionally worked.
Thanks
Been thanked: 0
Re: S70 Engine
Post by Thomas and Judith Lilli » Tue Jan 07, 2020 3:19 am
Sorry Gents, once again, I’m not getting notifications on this thread.
I would not have thought about an O2 sensor causing a burnt valve but, I just replaced the exhaust system and replaced the Heated O2 with the CCV. Curious how an O2 sensor would effect one cylinder as I thought it trimmed all fuel. Interesting. I do run the highest Octane I can get on every tank full although my wife generally drove the car and, like I said we’ve had it since it’s had about 40,000 miles (2002) so what’s that about 8000 per year but I’m driving it now so it will do much more. I have noticed the consumption of oil eased a little since we replaced the exhaust. I was thinking maybe the increased back pressure from the CCV being clogged might have pushed oil out if the recovery system in the crank case.
Been thanked: 0
Re: S70 Engine
Post by Thomas and Judith Lilli » Tue Jan 07, 2020 3:22 am
Also, will a professional diagnostic machine pick up poorly functioning O2 sensors?
E Showell
E Showell
Re: S70 Engine
Post by E Showell » Tue Jan 07, 2020 5:16 am
Here's my theory on the O2 sensor. They degrade slowly over time. Mine did not trigger a code. One possible mode of failure is to progressively lean out the mixture (you may notice a slight increase in fuel economy). Extra strain on the engine during say a prolonged highway Hill climb generates just enough extra heat to blowtorch the valve.
Chuck W
Year and Model: 97 854 T5
Has thanked: 18 times
Been thanked: 34 times
Chuck W
Re: S70 Engine
Post by Chuck W » Tue Jan 07, 2020 7:17 am
Pick up a good-running used motor. Swap it, and be on your way.
Been thanked: 0
Re: S70 Engine
Post by Thomas and Judith Lilli » Tue Feb 11, 2020 12:36 pm
An update!
Had some unrelated work done on the 90 degree gearbox. While in there, the tech changed the oil. He used Castrol GTX synthetic 5-30.
I’ve gone 1000 mile and have burned less than an eight of a court. Can’t figure it. I would have had to add a court by now.
Trinidad & Tobago
Re: S70 Engine
Post by abscate » Tue Feb 11, 2020 7:40 pm
My consumption fell on my T5 when I switched to synthetic.
The Syzygy of synthetic oil and leaks is an ongoing nuanced kerfuffle.
