Did you know? 🤔
1996 850 non-turbo | P0455 vacuum leak
jdw
Year and Model: '96 855 '73 1800ES
Has thanked: 5 times
Been thanked: 0
United States of America
jdw
Post by jdw » Sun Dec 29, 2019 12:29 am
I'm trying to resolve a vacuum leak on my 96 850 non-turbo manual for an upcoming CA smog check. Check engine light with code P0455 started appearing after a PCV job.
I've read posts like viewtopic.php?f=1&t=54546 on the typical leak areas but haven't found the weak spot.
- Hoses to the charcoal canister seem ok. Both hoses seem to hold pressure.
- Hoses near the tank including roll-over valve seem in-tact.
- EVAP purge valve holds vacuum (one way not energized, other way energized).
- Small hoses connect to vacuum T all hold vacuum except for the line to the airbox. Is it ok for the vacuum line to the airbox to hold no vacuum? Should the connection to the airbox (see arrow) have a check valve?
- A home made smoke tester mounted with a rubber glove over the intake is not indicating any leaks
Thanks in advance.
RickHaleParker
Has thanked: 3 times
Been thanked: 414 times
RickHaleParker
Re: 1996 850 non-turbo | P0455 vacuum leak
Post by RickHaleParker » Sun Dec 29, 2019 4:11 am
Did you check the gas cap seal for leaks?
Possible source
  • Leaking fuel tank, filler pipe, fuel tank filler cap, EVAP canister, EVAP canister shut-off valve or lines between these components.
    Blocked canister purge (CP) valve, EVAP canister, fuel tank pressure sensor or pipes between these components
    Sticking canister purge (CP) valve
    Defective fuel tank pressure sensor.
P0455 = EFI-611.
These users thanked the author RickHaleParker for the post:
jdw
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0,
Plant Torslanda Sweden.
jdw
Been thanked: 0
jdw
Post by jdw » Sun Dec 29, 2019 2:08 pm
Thanks for the reply Rick. The seal in the filler cap is dry but not cracked. I might just get a new one as it never has been replaced.
A lot of failure points identified by EFI-611 are near the tank. Maybe I should do some more smoke testing in that area.
The following components were not ready when the CEL came on: Catalyst, EVAP system, Oxygen Sensor.
Anyone know if the white tube going into airbox should hold vacuum? Thanks.
Has thanked: 254 times
Been thanked: 809 times
Trinidad & Tobago
Post by abscate » Sun Dec 29, 2019 2:29 pm
Yes it does. It drives the air box motor to regulate the air box temperature, so it doesn’t hold vacuum it’s letting in unmetered air into the throttle body
Link To Volvo Glossary
