Did you know? 🤔
Car died
Help, Advice, Owners' Discussion and DIY Tutorials on the Volvo S80 model. Sometimes called an "executive car", the S80 was and continues to be Volvo's top-of-the-line passenger car.
Brescar
Year and Model: 1999 s80
Has thanked: 0
Been thanked: 0
United States of America
Brescar
Car died
Post by Brescar » Tue Dec 31, 2019 12:39 pm
So i was driving my s80 and all the sudden it died, now it will bearly turn over any suggestions on what to look for
SuperHerman
Has thanked: 0
Been thanked: 162 times
SuperHerman
Re: Car died
Post by SuperHerman » Wed Jan 01, 2020 1:13 pm
Any lights? Can you hear the fuel pump? Any other information you can provide? Gas level sufficient?
June
Year and Model: 2004 S80 T6
Has thanked: 331 times
Been thanked: 167 times
June
Re: Car died
Post by June » Wed Jan 01, 2020 1:33 pm
Check the positive connection under the hood. Had the starter cable go bad and fry the fuse panel it's connected to in my 2004 S80 T6. The car suddenly died while running normally and would not restart like the battery suddenly died. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
Brescar
Has thanked: 0
Been thanked: 0
Brescar
Re: Car died
Post by Brescar » Fri Jan 03, 2020 5:16 pm
Yes there are headlights, but after charging the battery it still drags when we try to start it, and it has a full tank of gas, and duel pump sounds like it is clicking on, but dont seem like its getting fire, also here a clicking noise when trying to start it in a silver box that im thinking is the ETM electronic throttle module i believe
SuperHerman
Has thanked: 0
SuperHerman
Re: Car died
Post by SuperHerman » Fri Jan 03, 2020 8:48 pm
Check your serpentine belt and make sure it is there. While having someone turn it over make sure the alternator pulley is spinning. When asked about lights - I was asking about check engine lights. It could be your alternator failed and you don't have enough power. Charging the battery and getting it started should result in a warning light and/or error message regarding electrical power.
As June suggests, checking your cables is a good idea - also power related.
If the car does not have enough power all sorts of computer systems will not function correctly - so battery and fuel is the first place I would look.
Brescar
Has thanked: 0
Been thanked: 0
Brescar
Re: Car died
Post by Brescar » Sat Jan 04, 2020 3:52 pm
I have put a new battery in car but still drags whrn i try and start it, there are check engine and service engine lights that come im lost at whaT it could be, i dont have $ for a mechanic so hoping to figure it out. Thanks for all the imput
SuperHerman
Has thanked: 0
SuperHerman
Re: Car died
Post by SuperHerman » Tue Jan 07, 2020 8:01 pm
Check your timing belt - remove the cover and inspect. If it is intact and tight, try unplugging the MAF and see if it starts.
Without codes it is pure low lying fruit guesses.
Has thanked: 362 times
Been thanked: 1109 times
Trinidad & Tobago
Re: Car died
Post by abscate » Wed Jan 22, 2020 7:15 am
Get the battery on a 10 Amp charger for a full day, then report back how it cranks (turning engine over with key) and if it trying to fire at all.
Usually, when they go suddenly, its an electrical fault of some kind, but it can be in main charging, starting, or even fuel delivery system.
Link To Volvo Glossary
Brescar
Has thanked: 0
Been thanked: 0
Brescar
Re: Car died
Post by Brescar » Thu Jan 23, 2020 2:28 pm
Thx for the imput gonna try these things 🤞1 of them work that would be awesome ill let u know thx again
