Did you know? 🤔
Door chime all the time
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
dmg4
Year and Model: 1996 960
Has thanked: 1 time
Been thanked: 0
United States of America
dmg4
Post by dmg4 » Tue Dec 31, 2019 12:50 pm
I've just picked up a 1993 240 Classic wagon with one annoying trait: The door chime pings whenever the driver's door is open, irrespective of the ignition key position, lights off or on, etc. It's off when the door is closed, and you can of course kill it by pushing in the button on the switch on the driver's door jamb. But, why is this thing pinging away when the door is simply opened? Is the chime module faulty, or is there another cause?
Frequently wrong, never in doubt.
RickHaleParker
Has thanked: 3 times
Been thanked: 448 times
RickHaleParker
Re: Door chime all the time
Post by RickHaleParker » Tue Dec 31, 2019 3:15 pm
Key reminder. Does it chime with the keys out on the ignition and the driver's door open?
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0,
Plant Torslanda Sweden.
dmg4
Has thanked: 1 time
Been thanked: 0
dmg4
Post by dmg4 » Tue Dec 31, 2019 7:41 pm
"Does it chime with the keys out on the ignition and the driver's door open?"
Yes. Same result with key in or out of the ignition.
RickHaleParker
RickHaleParker
Post by RickHaleParker » Tue Dec 31, 2019 10:00 pm
I found it. The left front door switch grounds the Chime and activates it.
The Chime get it's power from the ignition switch so it should turn off with the key removal. Looks like two of the contacts in the ignition switch are wielded together.
You could deactivate the door Chime by cutting the White-Black wire on the Chime.
If you have a phantom load draining the battery, this could be it. You would need to replace the ignition switch if you want the chime to work the way it is designed to. If you do not want the chime, disconnect it.
See the attached file.
1992_240_EWD.pdf
These users thanked the author RickHaleParker for the post (total 2):
CSDentonTXdmg4
dmg4
Has thanked: 1 time
Been thanked: 0
dmg4
Post by dmg4 » Sat Jan 11, 2020 3:14 am
Thank you RickHaleParker! Looks like an easy repair of you can hang upside-down for 30 minutes. Now if I can just get those 27-yr-old ABS plastic covers off and back on without damage, it looks like I can fix this with a simple swap of a new switch.
I have to replace the handbrake cover-console anyway, so perhaps I'll just remove the front seats anyway so I can install the new console without cracking it. I modified the new console with an internal layer of glass cloth and epoxy resin, so it's never going to crack again.
