Did you know? 🤔
How to install windshield cowl LH and RH seals?
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
jamesf
Year and Model: 2005 XC90
Has thanked: 0
Been thanked: 0
United States of America
jamesf
Post by jamesf » Wed Jan 01, 2020 12:23 pm
I was getting lots of water in the passenger footwell and found the Swedish National Forest around the air intake underneath the windshield cowl. Once I cleaned everything up I could not figure out how to install these seals (PN 8862737 & 8862738 #23 on the windshield cowl PDF). The things that look like clips, maybe to attach to the fender? are cracked off which doesn't help.
download/file.php?id=2375
thanks,
jim
Year and Model: 2001 V70
Has thanked: 2 times
Been thanked: 28 times
Re: How to install windshield cowl LH and RH seals?
Post by volvolugnut » Wed Jan 01, 2020 1:07 pm
These seals attach in the bottom corners of the windshield. The plastic rivet clip that comes with the seals gets pushed into a hole in the pan (item 18). There are other posts about leaks into the passenger footwell.
See my post for a shield covering the air intake duct. viewtopic.php?f=9&t=92152
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
oragex
Year and Model: S60 2003
Has thanked: 92 times
Been thanked: 233 times
Canada
oragex
Post by oragex » Wed Jan 01, 2020 1:54 pm
Is driver's side dry under the carpet ?
Also verify the sunroof drains are clear, especially one on the pass side www.youtube.com/watch?v=MlaiU2ysB5E
jamesf
Has thanked: 0
Been thanked: 0
jamesf
Post by jamesf » Wed Jan 01, 2020 2:00 pm
Yep driver's side is fine. The sunroof drain hose on the passenger side was pinched under the pillar cover, but it flows after being readjusted. Next rainstorm it flooded again. There was enough water and crap under the cowl that I'm 90% sure that was the issue.
jim
oragex
Canada
oragex
Post by oragex » Thu Jan 02, 2020 6:33 pm
Oh, that was quite some forest there. Also around the intake for the cabin blower, there is a foam seal around the opening where the outer black plastic neck is seated against the car frame. Mine was displaced a little at some point, I think I see yours also coming loose a little bit, worth a look (pic). Finally, worth looking at the bottom cover of the cabin blower, if a previous owner removed it and didn't put back all 5 small screws tight enough (especially the hidden rear one), this bottom cover is not sealing and will leak water inside the cabin
