Reverse parking sensors
New to my family is a green V70 2.5T, on the rear of the car is what seems to be parking sensors. The previous owner was very vague with everything that was said and I took it as is. Because all the small faults like the door handle not opening, lights and dents I could fix. The parking sensors don't work but I've looked for where it would link into but I'm not sure. Some of the parts have been professionally repainted to make the car look whole. By the previous owner, I'm not quite sure what models or years came with that feature or if it was just added in. I'm also experiencing high idles far past the normal rpm when I start the car. Could it also be the throttle body going out?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
At cold start up the idle goes to 1700rpm for 30 sec to heat up the cat converter and prime the brake booster. Parking sensor was quite rare option, perhaps only needs a used sensor, maybe off Ebay ?
- RickHaleParker
- Been thanked: 977 times
Is the LED in the Park Assist switch on?heated wrote: 01 Jan 2020, 14:57 The parking sensors don't work but I've looked for where it would link into but I'm not sure.
Active
Past
Past
- RickHaleParker
It would be in the row of switches in the center console.heated wrote: 02 Jan 2020, 13:39 Not quite sure where that would be on the dash. Am I allowed to post imgur links?
Park Assist is an option not standard equipment.
Active
Past
Past
It’s standard on all P2s
If you have the switch, it goes “ beep”
If you don’t , it’s single “ crunch”
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
abscate wrote: 03 Jan 2020, 04:23 It’s standard on all P2s
When this feature is turned on, the radio display will say: "park assist aktive"
I thought at first that this is a gimmick, but I have come to appreciate it a lot and use it all the time.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- 7027 Views
Last post by oragex
- 11714 Views
Last post by packetfire
- 936 Views
Last post by jimmy57
- 639 Views
- 358 Views
Last post by erikv11
