Proud new owner of a well taken care of 2006 S40 T5 AWD with only 103K miles. Unfortunately, it has developed a minor electrical gremlin.
Primarily while accelerating or just maintaining speed the "Info" light on the dash will flash randomly, accompanied by the "Bulb failure, rear fog light" warning in the info display. Pressing the "OK" button doesn't get rid of it for long because the fault recurs, often within seconds. It almost always clears itself when you brake, so it's clearly something loose / rubbing / whatever.
I've seen mention on forums that this is a known issue with this generation of S40 / something others have experienced, but it's just mentioned in passing, no solutions being offered.
Bought this car a couple days ago, zero other issues with it, but this has gotten progressively worse and more annoying -- pretty sure I have an intermittent short or bad connection somewhere.
The flashing is annoying and distracting. My temporary solution is to pull the (working) bulb so I can just clear the warning once on start-up, but I don't like to drive around with things wrong with my cars, minor as this is.
Is there somewhere I should start looking, specifically, or am I going to have to trace the whole **** line back to source?
Thanks for any help or suggestions.
Intermittent "bulb failure" rear fog light, but bulb is good/works!
silentcircuit
- Year and Model: 2006 S40 T5 AWD
silentcircuit
Pulling and replacing the bulb and the connections on the associated assembly a few times seems to have cleared the fault for now, but I doubt this is a long term solution. Will update here if it comes back, and still looking for suggestions in the meantime. Thanks.
- 3385 Views
Last post by BasenjiDad19
- 463 Views
Last post by Lawrence1970
- 309 Views
Last post by aaronlife
- 2118 Views
Last post by BrickBetty
- 3243 Views
Last post by mikeamondo
