Did you know? 🤔
A satisfying fix: coin and buckle stuck in rear seat belt catch
Help, Advice, Owners' Discussion and DIY Tutorials on the third generation Volvo V70 wagon and XC70 crossover, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
popphl
Year and Model: 2008 V70
Has thanked: 0
Been thanked: 0
Liechtenstein
popphl
Post by popphl » Fri Jan 03, 2020 1:33 pm
I've got a 2008 V70 (217k miles & rolling strong!).
One of my kids dropped a dime in the back seat belt catch, then inserted the buckle. It became impossibly stuck, with the release button unable to be moved and the buckle and coin not retrievable -- tried brute force, lubrication, and all manner of thin tools. No luck.
The repair was not difficult. Turns out for this problem, here's what to do.
Source a Rear Seat Belt Catch -- mine was about $90 new online -- be sure to get the correct side; the right side has a single catch and the left side has two (for the center and left belts).
Pop off the seat cushion. To do this on a model with integrated booster seats, there are two 10mm bolts you have to remove first, and they are hidden under the booster seat instruction/warning label that you can see if the boosters are up. Peel the outside corner of that back, and you'll see 'em. Pop the seat up and out, and the seat belt catch is easy to see. One 14mm or 15mm bolt holds it in. Remove it, along with a wiring connector, and you can pull the catch out along with the stuck seat belt.
Now destroy the old seat belt catch with a hammer, being careful not to damage the belt buckle itself. This was the fun part. :evil: You'll get it loose easily, and you'll get to keep the dime, offsetting part of the cost of the new part.
Connect the connector, bolt the new catch back into place, put the seat back and bolt it in. Done in 30 minutes.
