Flashing up arrow and No speedometer
Hello everyone I have a problem with my 97 960 wagon I have a flashing up arrow with a check engine light on and my speedometer isn't working. My car is not in limp mode drives fine but after about 20-30 minutes it will start the problems. I can't find the problem any help would be amazing thank you.
- Year and Model: '96 965
- Been thanked: 9 times
Re: Flashing up arrow and No speedometer
I'm going through the flashing arrow right now and it's driving me batty. The 1st thing to do for the flashing light is to try another PNP switch on the transmission. I've already tried not 1, but 2 PNP switch's on mine that I disassembled and cleaned 1st. I've got other issues with my trans that I'm trying to sort out.
Won't help with your speedo issues. The signal to your speedo starts with a sensor on the diff cover.
96-964
91'745
86-635CSi 215K
Previous- 83 245T, 84 242, 85 242T, 92 960, 94 960, 95-964, 95-945
91'745
86-635CSi 215K
- Year and Model: 1994 Volvo 960
- Has thanked: 3 times
- Been thanked: 6 times
Joshua,
That sounds similar to the circumstances with my 94 960 sedan, but mine is intermittent. Flashing arrows on transmission mode selector switches and up arrow on the dash, begins several seconds AFTER my speedometer stops working. Then my speedometer will start working again but the flashing arrows don't go away immediately. They will go away eventually as long as the speedometer keeps working. I also found the other day that banging my first on the dash above the instrument cluster causes the speedometer to start working again. So I have a bad connection in the instrument cluster.
I have to pull the cluster, check connections on the back side of the cluster and if necessary the circuit board(s) inside of the cluster. I'm hoping that disconnecting the external connectors on the cluster and cleaning the contacts on the cluster and the connectors themselves will do the trick. If not, then I probably have a bad solder joint somewhere.
Just wanted to mention that clearly in my case the flashing arrows are triggered by the speedometer not working. You might approach it from that angle. Figure out why the speedo isn't working and you may also solve your flashing arrows issue. Hope this helps.
- Has thanked: 123 times
- Been thanked: 174 times
Both of these vehicles have electrical speedometer sensors likely located on the differential. They do not have mechanical speedometer cables. As electrical devices, they are likely to be integrated into the upshift indicators lights.
The sensors are likely magnetic pickups that count pulses as the tooth wheel or gear passes the sensor. They are prone to failure when they gather steel fillings on the magnet. Removal and cleaning may restore function.
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
- Year and Model: 760 1988
- Been thanked: 23 times
Check the main head light relay. It's the relay that is rectangular about the size of 2 standard relays. If this relay starts acting up it effects more than just the head lights.
1988 Volvo 760 Turbo Wagon
- 10 Replies
- 456 Views
Last post by misha
- 12 Replies
- 1155 Views
Last post by theWIFES_S70
- 841 Views
Last post by phils94850
