Amazon Black Friday deals
Boot light, switch, third brake light problems Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
S40volvo2007
Year and Model: 2007 S40
Has thanked: 2 times
Re: Boot light, switch, third brake light problems
Post by S40volvo2007 »
RickHaleParker wrote: Tue Jan 07, 2020 2:16 pm 10/19 = Third Brake Light.
what voltage should it read 12v or lower?
S40volvo2007
RickHaleParker wrote: Mon Jan 13, 2020 6:37 pm Ground pin #5 on the third brake light, see if it starts working.
Take some pictures of the connector on the third brake light. I cannot find anything for pins 2 - 4 but it looks like there should be a power line.
Had a closer look and it seems that third brake light is working when braking but is very dim you can see it but only just. There is a green connector with a yellow wire and a black wire.
RickHaleParker
Has thanked: 3 times
Been thanked: 631 times
Re: Boot light, switch, third brake light problems  Topic is solved
Post by RickHaleParker »
S40volvo2007 wrote: Sat Jan 18, 2020 6:20 am Had a closer look and it seems that third brake light is working when braking but is very dim you can see it but only just. There is a green connector with a yellow wire and a black wire.
Yellow (#1) is the power, measure the voltage.
Black (#5) is the ground, run a second ground to #5 and see if it brightens up.
Check the CEM electrical connectors. Make sure they are clean and in good condition. Even a thin layer of tarnish can cause problems.
2004 S60R, B8444S TF80 AWD.
S40volvo2007
Just an update, ground was fine but no luck with the third brake light, which pointed me to think I have a faulty led, so I grabbed a second hand one and installed, works perfect. Thanks for your help, that concludes my electrical issues with this great car.
