Amazon Black Friday deals
Cooler Oil Hose O-Ring Replacement
Rodplunger
Year and Model: 1998 V70 GTL
Post by Rodplunger »
Hi All,
This might be somewhere else, but I can't find it... I am replacing a leaking O-Ring on the cooler hose at the radiator fitting. The new ring is obviously still "large" and is not going into the housing with any ease. Are there any tricks to getting the new o-ring in? Grease? I would guess the oil itself would be enough lube, but I can't for the life of me get it to slide in... I am putting an OEM o-ring in that I bought at a dealer. Thanks for any advice.
I have attached photos of the before and after. The black one was the leaking gasket. It was firm and brittle. The green one is the OEM from the dealer. It is obviously larger than the original, as it should be. The other picture shows how far I can get the green ring into the fitting...
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 19 times
Been thanked: 12 times
Re: Cooler Oil Hose O-Ring Replacement
Post by hausmeister »
You can use silicone grease/spray or just engine oil... any oil should be fine I think.
If I remember correctly they can be a bit hard to get in (what she said) try some force as long as the oring is not cut up it should be fine.
s70 '98 2L na manual Image || 850 T5-R '95 auto Image
Has thanked: 412 times
Been thanked: 1270 times
A vice grip clamped on the back of the metal pipe, behind the flange, will give you good leverage your push that in
Link To Volvo Glossary
Year and Model: 2001 V70
Has thanked: 106 times
Been thanked: 157 times
Post by volvolugnut »
That O-ring does not have the 'look' of a typical O-ring sized for sliding fit. Perhaps the dealer supplied the O-ring for transmission cooler? Does it fit the groove width with a little gap? It kind of looks like the cross section diameter is too large for this application. That would make the outside diameter too large even if the inside diameter is correct.
When an O-ring gets compressed and flattened it has to expand in width. It does not really get compressed, it gets deformed.
I used to design O-ring sealing joints for machinery.
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
Rodplunger
I went to a different dealer, and it seems they gave me the wrong one. I picked up a black one that was much more similar to the one I pulled out of the car. I believe you are right about the green one being for the thermostat side... The new one fit very easily. Now to check for leaks.
volvolugnut wrote: Wed Jan 08, 2020 6:23 pm That O-ring does not have the 'look' of a typical O-ring sized for sliding fit. Perhaps the dealer supplied the O-ring for transmission cooler? Does it fit the groove width with a little gap? It kind of looks like the cross section diameter is too large for this application. That would make the outside diameter too large even if the inside diameter is correct.
This is a truly great , on point post with keen observational skills
+1000 MVS points and three passes for missing Oxford Commas, non-expiring and can be retroactively applied.
abscate wrote: Wed Jan 08, 2020 7:48 pm This is a truly great , on point post with keen observational skills
Thanks for the kind words. This old dog can still hunt.
