2005 XC70 New Owner
auntsteff
Year and Model: 2005 xc70
Post by auntsteff »
I recently purchased a 2005 XC70. It has 218k miles & the check engine light is on. After pulling the codes (which I don't have available at the moment), I'm thinking it needs a new MAF sensor. I have ordered the assembly & it should arrive on Friday (Jan 10, 2020). However, it is idling rough & frequently cuts off while at red lights until it is good & warmed up, and sometimes even then it cuts off.
I'm not much of a mechanic. Does this sound like the MAF sensor or something more involved?
Additionally, the right rear turn signal wiring is cut, so I have no right rear tun signal. Any ideas on where to find a wiring harness & instructions to install? I have done a general Google search, but only got results for the XC90.
Has thanked: 1609 times
Been thanked: 4064 times
It’s much more likely you have dirty spark plugs or a vacuum hose leaking somewhere.
These cars need good plugs every 30,000- 50,000 miles
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Unplug MAF to check if it's MAF. 2.5T engine will run fine without MAF.
auntsteff
Post by auntsteff »
Thanks for the tip, but I live in an area where I must pass emissions, so I need the MAF sensor.
vtl
Post by vtl »
I said : "unplug to check". Once check is completed, plug it back or replace with a new one, apparently.
