Did you know? 🤔
1997 850 ABS Question module test
mecheng
Has thanked: 4 times
Been thanked: 13 times
Canada
mecheng
Post by mecheng » Thu Jan 09, 2020 10:15 am
:? _Happy New Year MVS
My wifes 850 has a rebuilt Midwest ABS module, recently the ABS light has started coming on intermittently. I checked all the sensors and the resistance was in spec. After re-seating the module the abs light extinguishes once the car starts moving but it stays light after the initial engine start.
Is that normal, if so I assume that is because codes have been previously stored?
If not is there a way to erase the code?
Thanks
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Clemens
Has thanked: 95 times
Been thanked: 56 times
Austria
Clemens
Re: ABS Question
Post by Clemens » Fri Jan 10, 2020 12:37 am
I think that if you unhook the battery for a while the codes should be gone.
If not, I usually go to the dealer for that.
And, be sure that the connection and wires to the ABS unit are still in decent condition. Last time my ABS light came on intermittently I boticed that the 2 big black wires running to the module have peeling and cracked insulation and are oxidized green. I used WD40 as a temporary fix.
One more thing: if the system voltage drops really low
strange warning lights can come on. I had that even with a running motor, but the starting process must have drained the battery enough to screw up the dash lights.
Sometines my ABS and SRS lights take a few seconds longer than usual to go out.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Clemens
Austria
Clemens
Re: ABS Question
Post by Clemens » Fri Jan 10, 2020 12:50 am
Reading your post again: there is a self test of the ABS at around 25 mph.
Summer: 1996 855 R
Donor: 1995 854 10V
Has thanked: 361 times
Been thanked: 1108 times
Trinidad & Tobago
Re: ABS Question
Post by abscate » Fri Jan 10, 2020 3:47 am
Happy New Year MVS
Thanks
Adding to Clemens’ post, my experience below with low battery voltage !
viewtopic.php?f=1&t=92161
viewtopic.php?f=1&t=83660&p=456667&hili ... 80#p456667
Link To Volvo Glossary
mecheng
Canada
mecheng
Re: ABS Question
Post by mecheng » Mon Jan 13, 2020 8:13 am
Thanks all, where are the codes for the ABS stored, in the ECU or somewhere else? Does unplugging the battery reset ABS codes?
Matty Moo
Year and Model: 850, 1996
Has thanked: 0
Been thanked: 14 times
United States of America
Matty Moo
Re: ABS Question
Post by Matty Moo » Mon Jan 13, 2020 2:42 pm
Codes are stored in the abs module. Disconnecting the battery won't reset them, the light will stay on when there's an active fault.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
mecheng
Canada
mecheng
Re: ABS Question
Post by mecheng » Tue Jan 14, 2020 11:28 am
Thank you, that is what I thought. So I assume you guys use VIDA Dice?
Matty Moo
Has thanked: 0
Matty Moo
Re: ABS Question
Post by Matty Moo » Tue Jan 14, 2020 5:10 pm
Vida doesn't work on 96-98 cars. I use vol-fcr.
2000 s70 GLT
2014 Ram
mecheng
Canada
mecheng
Re: ABS Question
Post by mecheng » Thu Jan 16, 2020 9:57 am
Is their a specific Vag Com cable that would work best, I found two different ones:
https://www.ebay.ca/itm/KKL-VAG-COM-409 ... SwGIZcQZw7
or
https://www.ebay.ca/itm/NEW-USB-Cable-K ... 6bf47b29c4
Is their a site for the Vol FCR software? I don't see it listed on ebay.
Thank you
my98s70glt
Year and Model: 98 S70 GLT; 07 V70 2
Has thanked: 2 times
Been thanked: 3 times
my98s70glt
Re: ABS Question
Post by my98s70glt » Thu Jan 16, 2020 10:46 am
This cable was recommended to me... works fine on my ‘98.
https://rover.ebay.com/rover/0/0/0?mpre ... 3706541827
Did you check this site for the software?
https://vol-fcr.software.informer.com/1.7/
Current:
1998 S70 GLT: T5 ECU || 16T Turbo || White Injectors || Snabb RIP Kit || Snabb Fresh Air Pipe || Bilstein Touring || Eibach Lowering Springs || 17” Neptunes
2007 V70 2.5T: Snabb Fresh Air Pipe || BC Racing Coilovers
Previous: 2006 V70 2.5T, 2011 C70 T5, 2012 S60 T5, 2000 S70 GLT/SE
