Head Unit With DAB, GPS - first generation XC90 with premium sound
geirmeister
Year and Model: XC90 2003
Has thanked: 1 time
Post by geirmeister »
Hello,
I have this first generation XC90 with premium sound system, (6CD unit no AUX). The FM band is disappearing here in Norway, the RTI can't read the DVD and I'm running out of CDs, so it's time for an upgrade. However, I have not been able to find a suitable head unit. I want to pull out the RTI display and install the new unit there, so I can keep the CD changer and the MOST. So I am looking for a (not too expensive) solution with DAB, GPS, CANbus and the usual Android features. Most of the things I have found on the net lack some desired features and forum posts seem to be several years old.
Any useful experience/ideas are welcome :)
Geir
Reason: Edited title. Please, no "ALL CAPS"s in titles.
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
I will tell you what little I know on upgrading the early XC90 sound system based on research I did before I decided to scrap the idea and give the car to my sister - less than a year old information.
It is unclear if the entire unit can be removed in its entirety and a specific module purchased to replace what Volvo designed into the system. I read some talk in this direction, but it was not conclusive. What I did conclude as a working solution is keeping the display, but mounting it internally. Apparently it is needed b/c it is part of the system. Utilizing a correct wiring harness almost any deck can be fitted. You would lose the 6 CD changer (which takes up most of the double din space as the display is actually rather small), but would gain all sorts of current/modern functionality options - blue tooth, hands-free, streaming, maybe TV in your area, back up camera, front camera, GPS ... - this would depend on what kind of unit you purchase. You can put in a single or double din - it is your choice.
Basically if you keep the display (tuck it away in the radio cavity), buy or make the correct harness any unit can be fitted.
There are videos on it if you look.
geirmeister
Has thanked: 1 time
Yes, that was as far as I got too, so I thought that if I could get a unit that fits where the RTI screen is, I could keep most of the original setup and save some hassle. The question is if there is such a unit...
Geir
