Did you know? 🤔
2007 XC70 does not start in cold temperature (battery is good)
2001 - 2007 XC-70
GabrieS
Year and Model: 2007 XC70
Has thanked: 2 times
Been thanked: 0
Canada
GabrieS
Re: 2007 XC70 does not start in cold temperature (battery is good)
Post by GabrieS » Fri Feb 07, 2020 9:09 am
-5 degrees outside today but the car would not start at all.
I thought about warming up some of the parts that are potential offenders.
I have taken the hair dryer and placed it for about 10 minutes on the parts listed below with no results. I made sure they felt nice and warm to touch and would then crank the engine...but no success.
- PEM (Pump Electronic Module)
- ECM/PCM (the two modules under the hood inside a plastic box with a plastic lid on the passenger side)
- Starter
I googled "Volvo XC70 starter issues" and I found one user (WyoXC - post#17) on another forum say this:
However it is not something that people say consistently in that thread and at the same time my starter cranks just fine...so it still feels like a shot in the dark.
Dwwalker...Please post if your issues have resolved after more time has elapsed with the replaced starter.
Thanks
Has thanked: 266 times
Been thanked: 844 times
Trinidad & Tobago
Post by abscate » Fri Feb 07, 2020 12:01 pm
- Starter
Thanks
Its the perfect time for this test
Here is the cheap diagnostic next time the no-start occurs
A three second blast of starting fluid (ether, or di-ethyl ether, same thing) into the snorkel, followed by cranking, will tell you if you have a cold induced fuel delivery problem.
If it suddenly breathes fire on ether, then your fuel is not getting delivered properly.
Link To Volvo Glossary
GabrieS
Been thanked: 0
Canada
GabrieS
Post by GabrieS » Fri Feb 07, 2020 10:19 pm
I had the starter fluid ready but when I went to do it...I realized there is nowhere for me to access the air intake. I lifted up the air box from the air filter but it has a long pipe running down and behind the engine under the firewall.
I was unable to disconnect anything to get close to the air intake.
I know this is very easy to do on lots of cars because the air intake usually sits on top of the engine...but not on this car.
Unless you have a better spot for me to spray the starter fluid in...I cannot access the air intake.
Sorry...I was going to do this test and had everything ready...and then this happened.
- Pete -
Has thanked: 34 times
Been thanked: 56 times
United States of America
- Pete -
Post by - Pete - » Fri Feb 07, 2020 10:58 pm
At the top of the airbox lid there is a “honey comb”. Just behind that sits your MAF. Use the red pipe on the side of the ether can & with someone in the drivers seat hitting the key, shoot the ether past the MAF, down the intake runner (tube). I try to avoid getting ether near the MAF, they aren’t free to replace & can be damaged easily.
2001 V70XC 142k
2004 V70 AWD 134k
2004 V70R M66 142k
2004 XC70 278k
2006 XC70 155k Sold
Trinidad & Tobago
Post by abscate » Sat Feb 08, 2020 3:35 am
You ca also pull any vacuum line on the intake tree and use the red stinger to shoot three seconds into the manifold.
Abscate has a paychecking riding on the outcome that it will breathe no fire.
ADent
Year and Model: v70 T5M 2001
Has thanked: 0
ADent
Post by ADent » Thu Feb 13, 2020 2:01 am
How about heating the CEM? Under the dash. I think mine is flaking out in the cold.
dwwalker
Year and Model: S40 2001
Has thanked: 0
Been thanked: 0
Canada
dwwalker
Post by dwwalker » Fri Feb 14, 2020 8:15 am
Per mrbrian, it's the starter. The car thermometer said -23C this morning but the house one said -18C. Either way my car wouldn't start at that temperature before. With the new starter it started right up like it did yesterday. No pulsing of the tach etc. Without that background of the EM field I might never have figured it out. The starter still turned. Thanks.
mrbrian200
Has thanked: 7 times
Been thanked: 80 times
mrbrian200
Post by mrbrian200 » Mon Feb 17, 2020 8:33 am
Please report back after a few more nights at that temperature or lower. I like to see consistent behavior over time. Once in awhile something appears to be fixed but is a one-off/ issue remains. Sounds promising though!
