First, this thread - viewtopic.php?f=1&t=65002 ( 850 AND S/V/C70 NON-TURBO VACUUM LINES) covers quite a lot, but there are differences between what's shown there and what is on my '99 S70 that just add to the overall murky confusion surrounding the layout of the vacuum lines on these cars.
Mine has no vacuum tree, flame trap or nipples on the throttle body as are shown in that guide.
Since the engine is currently partially apart, I've photographed what I believe are all the small vacuum line attachment points aside from the brake booster, fuel pressure regulator and charcoal canister as all are a bit hard to get to (the fuel pressure regulator is underneath the car, near the fuel filter behind the rear passenger side wheel).
These photos have each nipple numbered. What I'd like to do is compile a list of what attaches to each of them so there will be a concise reference for this particular setup.
The connections seem to be as follows. Those with a question mark at the beginning are unconfirmed. Corrections are welcome...
(Revised)
#1) Intake Manifold to Purge Valve, Upper (#7)
#2) White Rigid Line. Intake Manifold to Rear of Air Cleaner, Lower (#9)
#3) Intake Manifold to Vacuum Solenoid On Top of Radiator
#4) Intake Manifold to Brake Booster
#5) To Air Intake, #13 *
#6) Purge Valve, Lower to Fuel Regulator
#7) Purge Valve, Upper To Intake Manifold (#1)
#8) Black Rigid Line to Air Cleaner Air Valve (#11)
#9) White Rigid Line. Rear of Air Cleaner, Lower to Intake Manifold (#2)
#10) Oil Trap to Fresh Air Intake (#12) <There seems to be a missing elbow on this line> *
#11) Black Rigid Line From #8 on Rear of Air Cleaner, Upper
#12) To Oil Trap (#10)
#13) To #5 on Passenger Side of Intake Manifold
* These two (#5 and #10) run inside the same foam sleeve. The #5 hose in not shown in these photos.
'99 S70 Non Turbo Vacuum & Related Lines - Different Version
- Electrix
- Year and Model: 1999 S70
Re: '99 S70 Non Turbo Vacuum & Related Lines - Different Version
For further clarity, here are the part numbers for the some of the relevant components -
Purge Valve - Pierburg PA6-GF30
Intake Manifold - 9434314
Fresh Air Hose - 9155453
Air Cleaner - 9125215
Air Cleaner Valve - PP-GF-30 (This doesn't seem to be the part number, but it was the only one visible)
Oil Trap - Likely 8692211. Unconfirmed
- Has thanked: 716 times
- Been thanked: 312 times
Beautiful.
Marked for inclusion in the Volvo Repair Database VRD.
Also -> Amazon link. Click that when you go to buy something on Amazon and MVS gets a kickback.
1997 850 T5, MSD ignition coil, Hallman manual boost controller, injectors, R bumper, OMP strut brace [gone]
- Year and Model: 99T5 ,99S70,2005V70
- Has thanked: 443 times
- Been thanked: 1339 times
Can you add a picture of your under hood sticker for reference and also add your build date?
I have exactly the same car , by the way, and some different hose routings
Link To Volvo Glossary
Electrix made MVS Contributor
Topic Added to VRD
Topic Added to VRD
- Electrix
A picture of the vacuum routing sticker from under the hood is attached below
The build date is 10/98 according to the sticker on the driver's door frame.
Some other assorted information from a VIN decoder site -
Engine Model: B5254S
Pretensioner: Yes
NCSA Make: Volvo
NCSA Model: 70 Series (For XC70 for 2014 on, use model code 402)
Other Restraint System Info: Dual Airbags (SRS)
Other Engine Info: w/o EGR, w/o air pump, w/OBDII, w/air-assisted fuel injectors, Denso, w/RuLo, w/ORVR Transmission: auto and manual
Manufacturer Id: 1006
I'd consider the chart I've made tentative until the car is running again and all the lines are attached. It might be another week or two until I've reached that point.
- smacknab
- Year and Model: 99 s70 NA Manual
- Has thanked: 73 times
- Been thanked: 21 times
Hey electric, first thanks for the diagram, it matches my car and I've used it a couple times.
Second, does your car have an airpump? Or an air pump relay?
I noticed mine doesn't have an airpump relay, and I didn't see any mention of air pump hoses routing in your post. I'm trying to solve a mystery of is mine ever had to begin with.
Thanks,
Sean
99 s70 NA Manual - >225k miles
Mods: Accidental C70 Delta link, V70 Left Dog Leg
- 286 Views
Last post by Archer
- 245 Views
- 1362 Views
Last post by erikv11
- 156 Views
Last post by ShadyMilkMan
- 409 Views
Last post by m96ag
