Did you know? 🤔
Stalling Out
2001 - 2007 XC-70
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 13 times
United States of America
Mr. Detail
Stalling Out
Post by Mr. Detail » Sat Jan 11, 2020 10:20 am
Ok, here is my latest issue after replacing all five ignition coils and replacing all five spark plugs. Whenever I first start up the car in the morning, she shakes quite a bit before reaching the middle of the engine warm up gauge.
This seems to be whether it is cold outside or warm like today (60 deg.).
In fact, I thought because it was so warm out today I could just start her up and go but at the first stop sign the car just died. I re-started it several times before I could get it to move forward. Once it reached the middle of the engine temp gauge it was fine. Any thoughts why this stalling out issue is happening? No check engine light.
Thanks.
RickHaleParker
Has thanked: 3 times
Been thanked: 414 times
RickHaleParker
Re: Stalling Out
Post by RickHaleParker » Sat Jan 11, 2020 11:59 am
Check the resistance of the Engine Coolant Temperature (ECT) sensor against the engine coolant temperature.
15 kΩ at -20°C ( -4°F)
2.5 kΩ at 20°C (68°F) Typical room temperature.
0.3 kΩ at 80°C (176°F) This is 10 - 25°C below operating temperature*.
* OEM thermostat starts to open at 90°C (194°F), fully open at 105°C (221°F)
At 60°F the resistance should be ~2.0 - 2.5kΩ.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0,
Plant Torslanda Sweden.
Has thanked: 254 times
Been thanked: 809 times
Trinidad & Tobago
Re: Stalling Out
Post by abscate » Sat Jan 11, 2020 1:58 pm
I just bumped the cold start rough running thread whose root cause was a really badly torched vacuum hose
Link To Volvo Glossary
Mr. Detail
Mr. Detail
Re: Stalling Out
Post by Mr. Detail » Sun Jan 12, 2020 5:29 am
RHP, would the ECT sensor really cause the engine to completely cut out like it did several times? I was dead on the road and had to put it in drive and then re-start at least four times.
Thanks abscate for the bumped thread. I will look for that now.
Mr. Detail
Mr. Detail
Re: Stalling Out
Post by Mr. Detail » Sun Jan 12, 2020 5:30 am
By the way can anyone shoot me a snapshot of where the ECT sensor is?
Trinidad & Tobago
Re: Stalling Out
Post by abscate » Sun Jan 12, 2020 8:03 am
On a P2 follow the upper right radiator hose, the thick one, back towards the engine. It connects to a housing which contains the thermostat and the ECT sensor
Mr. Detail
Mr. Detail
Re: Stalling Out
Post by Mr. Detail » Sun Jan 12, 2020 10:37 am
Thank you abscate.
On your earlier post about a "torched vacuum hose/line". Did anyone ever state which specific vacuum hose went bad?
RickHaleParker
RickHaleParker
Re: Stalling Out
Post by RickHaleParker » Sun Jan 12, 2020 11:27 am
Faulty readings from the ECT can cause the ECM to miscalculate the air-fuel mix.
Trinidad & Tobago
Re: Stalling Out
Post by abscate » Sun Jan 12, 2020 5:23 pm
Thank you abscate.
I don’t think I named it , but I showed lots of pictures
:D
Mr. Detail
Mr. Detail
Re: Stalling Out
Post by Mr. Detail » Mon Jan 13, 2020 9:01 am
Is there a special socket I will need to loosen the old ECT sensor as the wire is still attached?
Not sure yet of that hex size.
