IPD sale XeMODeX - Experts in Volvo Electronics Free shipping all USA - Experts in Brakes
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
2002 V70 NA Stalling Out Cold, runs well hot
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
E Showell
Year and Model: V70R '06 AWD Auto
Has thanked: 13 times
Been thanked: 58 times
United States of America
E Showell
Re: Stalling Out
Post by E Showell » Mon Jan 13, 2020 10:50 am
As a quick and dirty diagnostic on ECT fault, when next experiencing hard starting, fully depress accelerator. If it starts right up, that is suggestive of ECT issues. When ECT malfunctions, it over enriches mixture on starting so you have, in essence, a flooded condition. Depressing gas pedal adds more air to the mix to compensate for the flooding.
'99 V70 NA FWD Auto, dark blue (actively for sale)
'06 V70 R AWD Auto, Sonic Blue Metallic
'04 XC70 Ruby Red Metallic
'95 855 auto (sold)
'86 245 manual (sold)
highmiles
Year and Model: 2001 S60 T5
Has thanked: 7 times
Been thanked: 3 times
highmiles
Re: Stalling Out
Post by highmiles » Mon Jan 13, 2020 1:19 pm
My 2001 S60 uses a 19mm wrench. Due to the wire, you wont be able to get a socket on it. The thermostat housing changed somewhere between 01 and 03 on the S60, on the 2001 I removed the top of the housing to get enough access to fit the wrench. The later model has a body that is not intended to be disassembled, but the ECT sensor is lower and looks to be more accessible
Mr. Detail
Year and Model: 2002 V70 N/A
Been thanked: 2 times
Mr. Detail
Re: Stalling Out
Post by Mr. Detail » Tue Jan 14, 2020 6:11 am
Would you guys recommend also replacing the thermostat since I already have the housing removed?
amblerman
Year and Model: 1999 s70
Has thanked: 1 time
Been thanked: 27 times
amblerman
Re: Stalling Out
Post by amblerman » Tue Jan 14, 2020 11:08 am
You could use either an open ended wrench or a special line wrench that looks like a closed box wrench with a slit cut into it.
I watched a video on this and he used a 3/4 open wrench to bust it open. 3/4 in = 19.05 mm so I'm guessing its a 19mm
If you wanted a socket style, you'd have to get a 19mm O2 sensor socket . That's a socket with a slit cut up side to accommodate the wire
These users thanked the author amblerman for the post:
Mr. Detail
amblerman
Has thanked: 1 time
amblerman
Re: Stalling Out
Post by amblerman » Tue Jan 14, 2020 11:39 am
Mr. Detail wrote:
Sun Jan 12, 2020 5:30 am
By the way can anyone shoot me a snapshot of where the ECT sensor is?
purple - ECT
red = thermostat (thermostat housing removed)
Mr. Detail
Mr. Detail
Mr. Detail
What's next?
Post by Mr. Detail » Mon Feb 10, 2020 6:14 am
OK, with the help of one of our forum guys, "Amblerman" we were able to change out the ECT coolant sensor over the weekend. I was hoping that would resolve my hard start up issue but it has not.
I have already changed out the ignition coils and also the plugs.
The car shakes badly when first turned over and I have to hold the accelerator down to keep the rpm's up until it warms up. Once warmed up there are no issues.
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 287 times
Been thanked: 904 times
Trinidad & Tobago
Re: What's next?
Post by abscate » Mon Feb 10, 2020 7:00 am
IS there an original thread here so we can look at the history again?
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
Mr. Detail
Mr. Detail
Re: What's next?
Post by Mr. Detail » Mon Feb 10, 2020 8:58 am
I think this is it.
viewtopic.php?p=529862#p529862
Trinidad & Tobago
Re: 2002 V70 NA Stalling Out Cold, runs well hot
Post by abscate » Mon Feb 10, 2020 9:15 am
OKay, merged them up
Have a look at the vacuum line running off the manifold, heading left (towards driver) to a T junction or check valve (there are slight differences) - remove all hoses, inspect, clip off ends, test check valves, look for cracks. This will take about an hour.
The NA engine management runs the car at high idle for the first 30 seconds to burn off the excess gas, is it going to 1500 rpm for about 30 seconds, then slowing to normal idle speed?
Mr. Detail
Mr. Detail
Post by Mr. Detail » Mon Feb 10, 2020 10:22 am
Wen you speak of looking at the vacuum line, running off the manifold. heading left (towards the driver) this seems backwards if i am standing in front of the car at the grill and looking towards the windshield. Towards the driver would be "right', correct?
Yes, the car is beginning at a high idle when first turned over and then it slowly drops down. But when it drops down to normal idle (750-800 rpm's) the car shakes like hell. If I start to drive the car within 1 or 2 minutes after starting it will die out/shut down on the road. I have to almost wait 5-10 minutes until the temperature gauge show the needle in the middle before I can drive it successfully.
