Hi,
I was changing the oil today on my 2009 S80 3.2 (96,500 miles), and noticed some sort of oil on the driver’s side of the plastic tray that you have to remove to access the oil pan plug. I then looked in the engine, and noticed that the entire area around where the transmission fluid fill port is located is covered with some sort of oil.
Any idea of what could be leaking? Oil level was fine when I changed the oil today, and brake fluid level, steering fluid level, and coolant levels were fine.
Thanks for any help you can provide!
Oil Leak in Engine Compartment
drewmeister2
- Year and Model: 2009 S80
- June
- Has thanked: 523 times
- Been thanked: 261 times
Check the transmission fluid. It could be leaking or it may have overheated. If the transmission fluid gets too hot it will percolate out the vent or dipstick. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
drewmeister2
Thanks. There is no dipstick on this model. I should note, there is some oil on some engine components above the transmission fluid fill plug as well.
drewmeister2
Thanks. There was some oil around there. Is that crankshaft oil leaking out of there, then?
- 1496 Views
Last post by bronco
- 852 Views
Last post by Dinesh78
- 657 Views
- 1221 Views
Last post by TheGlue
- 25 Replies
- 6645 Views
Last post by bmdubya1198
