Did you know? 🤔
Oil Leak in Engine Compartment
Help, Advice, Owners' Discussion and DIY Tutorials on the third generation Volvo V70 wagon and XC70 crossover, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
drewmeister2
Year and Model: 2009 S80
Has thanked: 0
Been thanked: 0
United States of America
drewmeister2
Post by drewmeister2 » Sun Jan 12, 2020 6:04 pm
Hi,
I was changing the oil today on my 2009 S80 3.2 (96,500 miles), and noticed some sort of oil on the driver’s side of the plastic tray that you have to remove to access the oil pan plug. I then looked in the engine, and noticed that the entire area around where the transmission fluid fill port is located is covered with some sort of oil.
Any idea of what could be leaking? Oil level was fine when I changed the oil today, and brake fluid level, steering fluid level, and coolant levels were fine.
Thanks for any help you can provide!
June
Year and Model: 2004 S80 T6
Has thanked: 255 times
Been thanked: 137 times
June
Re: Oil in Engine Compartment
Post by June » Sun Jan 12, 2020 6:10 pm
Check the transmission fluid. It could be leaking or it may have overheated. If the transmission fluid gets too hot it will percolate out the vent or dipstick. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
drewmeister2
Has thanked: 0
Been thanked: 0
drewmeister2
Re: Oil Leak in Engine Compartment
Post by drewmeister2 » Sun Jan 12, 2020 6:30 pm
Thanks. There is no dipstick on this model. I should note, there is some oil on some engine components above the transmission fluid fill plug as well.
Steve H
Year and Model: 2008 S60 2.5T & XC70
Has thanked: 1 time
Been thanked: 5 times
Steve H
Post by Steve H » Sun Jan 12, 2020 6:36 pm
Check your brake vacuum pump where it bolts to the head. Common seal leak. See video link.
drewmeister2
Has thanked: 0
Been thanked: 0
drewmeister2
Post by drewmeister2 » Sun Jan 12, 2020 7:20 pm
Thanks. There was some oil around there. Is that crankshaft oil leaking out of there, then?
