Did you know? 🤔
A/C Compressor Howl
2001 - 2007 XC-70
highmiles
Year and Model: 2001 S60 T5
Has thanked: 7 times
Been thanked: 3 times
United States of America
highmiles
A/C Compressor Howl
Post by highmiles » Mon Jan 13, 2020 1:08 pm
Still on the path to having my 2001 S60 T5 5-speed back on the road (purchased it as a timing belt failure car with partially disassembled motor,) and have found one final (I hope...) hurdle.
The car would start OK when cold, but with a howling noise (turbo?, PS pump?, A/C compressor?) that would go away after 5-10 seconds and then run well without noise. However, warm/hot starting was more difficult.
This weekend I hooked the car up to VIDA and manually kicked on the A/C compressor while the car was running, instant stall. I then disconnected the electrical connector at the compressor and found no more howl and easy warm/hot starts. I can only guess that, even with the climate control set to "off," the computer still kicks in the A/C compressor briefly at start up?
So the question of the day is... is there anything to be done to free up the compressor? I assume it has low pressure since it never kicked on even from the climate control system or switching to defrost.
There are plenty available at the pull-a-part, that is my plan for the weekend unless there is magic to perform the one in the car.
Thanks! John
ps. the combination of the 2.3 with high pressure turbo and the manual transmission is a darn quick package!
Has thanked: 252 times
Been thanked: 809 times
Trinidad & Tobago
Re: A/C Compressor Howl
Post by abscate » Mon Jan 13, 2020 1:20 pm
This is one of those deep P2 understanding realms that you have entered
If I recall, the AC in a P2 changed from COTS to the newer type(forgot the acronym) and one of the other changes is it briefly kicks on the compressor at start, to push out any condensed Freon in the condenser from shutdown.
If i got anything really wrong here, jimmy will fix it.
Laying waste to the BMWs ....especially if you stay in the power range of 2nd and 3rd gear
Link To Volvo Glossary
oragex
Year and Model: S60 2003
Has thanked: 92 times
Been thanked: 226 times
Canada
oragex
Post by oragex » Mon Jan 13, 2020 4:10 pm
This is for the clutch bearing and the shims www.youtube.com/watch?v=KAGDkwYSFY4 BUT from what you are describing, I would guess it's rather the compressor itself, maybe overcharged/undercharged or perhaps a faulty expansion valve ?
highmiles
highmiles
Post by highmiles » Tue Jan 14, 2020 8:46 am
Thanks for the responses.
I should have hooked up the gauges to it, I will next weekend just to see if it has any pressure in it. Since the car sat for some time I surmise it is locked up mechanically, though the system was left closed the whole time.
Still planning a junk yard run for Saturday...
RickHaleParker
Has thanked: 3 times
Been thanked: 414 times
RickHaleParker
Post by RickHaleParker » Tue Jan 14, 2020 9:13 am
To keep the compressor oil from settling. The compressor oil is part of the sealing. If the compressor oil settles the refrigerant will leak out. This is why cars that have been sitting for a long period of time need a refrigerant recharge when put back on the road.
These users thanked the author RickHaleParker for the post:
highmiles
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0,
Plant Torslanda Sweden.
Trinidad & Tobago
Post by abscate » Tue Jan 14, 2020 11:19 am
Indeed, Freon isnt going to condense in a system shut down at any normal temperature. Oil it is.
