Hi - A few weeks ago my friend who has worked on all my 240's through the years had my 1991 240 to fix the windshield wiper motor. When he went to drive the car he couldn't turn the ignition key off and the car was stuck running. He kept the car and on his advice, I ordered a used ignition lock that came with door locks and keys, and he put those in. When I picked up the car it started fine, so I drove it home - same issue. I had to pull the wire off the ignition switch and disconnect the battery. I suspect the issue is due to something else (shifter?) and would appreciate any advice.
P.S. When I picked the car up, I realized while backing up that pulling the steering wheel toward me at all would cause the horn to honk. Don't know if this could be related but ...
Key stuck in ignition can't turn off engine Topic is solved
michelleives
- Year and Model: 1991 240
- Has thanked: 1 time
- RickHaleParker
- Been thanked: 977 times
The whole Column Lock (#2) or just the Lock Cylinder (#5)?michelleives wrote: 14 Jan 2020, 09:49 I ordered a used ignition lock that came with door locks and keys, and he put those in.
Active
Past
Past
michelleives
- RickHaleParker
Disconnect the Interlock Cable form the Column Lock and try moving the piece the cable is hook to and remove the key.
Active
Past
Past
michelleives
SOLVED - Well it turned out that the $39 ignition switch that I had ordered from IPD was faulty. Bought one from autozone for $177 and everything is working fine now. Thanks for the suggestion RickHaleParker.
- 4170 Views
- 11639 Views
Last post by RickHaleParker
- 21 Replies
- 2861 Views
Last post by sleddriver
- 4160 Views
Last post by rfm77555
- 10239 Views
Last post by ppembe62
