Did you know? 🤔
Key stuck in ignition can't turn off engine
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
michelleives
Year and Model: 1991 240
Has thanked: 0
Been thanked: 0
United States of America
michelleives
Post by michelleives » Tue Jan 14, 2020 9:49 am
Hi - A few weeks ago my friend who has worked on all my 240's through the years had my 1991 240 to fix the windshield wiper motor. When he went to drive the car he couldn't turn the ignition key off and the car was stuck running. He kept the car and on his advice, I ordered a used ignition lock that came with door locks and keys, and he put those in. When I picked up the car it started fine, so I drove it home - same issue. I had to pull the wire off the ignition switch and disconnect the battery. I suspect the issue is due to something else (shifter?) and would appreciate any advice.
P.S. When I picked the car up, I realized while backing up that pulling the steering wheel toward me at all would cause the horn to honk. Don't know if this could be related but ...
RickHaleParker
Has thanked: 3 times
Been thanked: 416 times
RickHaleParker
Re: Key stuck in ignition can't turn off engine
Post by RickHaleParker » Tue Jan 14, 2020 1:08 pm
The whole Column Lock (#2) or just the Lock Cylinder (#5)?
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0,
Plant Torslanda Sweden.
michelleives
Has thanked: 0
Been thanked: 0
michelleives
Post by michelleives » Tue Jan 14, 2020 2:50 pm
RickHaleParker
RickHaleParker
Post by RickHaleParker » Wed Jan 15, 2020 4:26 pm
Disconnect the Interlock Cable form the Column Lock and try moving the piece the cable is hook to and remove the key.
