Hello everyone, in a previous post I was having issues with my wife's O2 XC70 being stuck in a limp mode after replacing a broken serpentine belt. I'm wondering if while she was driving the car off of the battery power the low voltage may have caused the accelerator pedal to stop communicating with the ECM or something of that nature? After further research I believe that either the throttle control module or the accelerator pedal need to be readapted to the ECM. Does anyone have experience with this process? I was planning on ordering the Vida/Dice software and trying this process. Thanks in advance for any advice.
Codes p2126 and p2121
TCM/Accelerator Pedal adaptation
Ftknox1301
- Year and Model: 2002 XC70
- Has thanked: 1 time
highmiles
- Year and Model: 2001 S60 T5
- Been thanked: 4 times
I read through your previous post. What is the current state of the car? Is it running at all? Cranks but won't fire? Check engine light?
Does the battery have a full charge?
Have you tried disconnecting the battery all together? It seems I have also heard to wait "x" minutes and or touch the cables together to fully discharge any latent charge in the car.
I have found VIDA to be pretty indispensable in trouble shooting these cars, the generic codes are just not very helpful.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
You'll need a fully charged battery set up to come out of LIMP cycle -- it is a fuel shut-off, i.e., ECM taking away AP function from you for safety. VIDA DiCE is must have in your situation.Ftknox1301 wrote: 14 Jan 2020, 17:59 Hello everyone, in a previous post I was having issues with my wife's O2 XC70 being stuck in a limp mode after replacing a broken serpentine belt. I'm wondering if while she was driving the car off of the battery power the low voltage may have caused the accelerator pedal to stop communicating with the ECM or something of that nature? After further research I believe that either the throttle control module or the accelerator pedal need to be readapted to the ECM. Does anyone have experience with this process? I was planning on ordering the Vida/Dice software and trying this process. Thanks in advance for any advice.
ETM needs to power down fully to erase its memory before the car is normally driven, otherwise the fault may be set in the ECM again.
For the ECM and ETM to power down fully the ignition should be turned off for 5 minutes each time, if the cooling fan is running you will need to wait until 2 minutes after the cooling fan has stopped to ensure the ETM is powered down.
Ftknox1301
Yes I'm definitely going to get the software since I have two of these cars, but should I be able to get the car back to its normal running condition by simply charging up the battery? I have had to jump start the car a few times but I've never put it on the battery charger. I've also had the battery totally disconnected for a few days and also touched the positive and negative battery cables together for a few seconds to clear any codes still in the ECM.xHeart wrote: 15 Jan 2020, 11:20You'll need a fully charged battery set up to come out of LIMP cycle -- it is a fuel shut-off, i.e., ECM taking away AP function from you for safety. VIDA DiCE is must have in your situation.Ftknox1301 wrote: 14 Jan 2020, 17:59 Hello everyone, in a previous post I was having issues with my wife's O2 XC70 being stuck in a limp mode after replacing a broken serpentine belt. I'm wondering if while she was driving the car off of the battery power the low voltage may have caused the accelerator pedal to stop communicating with the ECM or something of that nature? After further research I believe that either the throttle control module or the accelerator pedal need to be readapted to the ECM. Does anyone have experience with this process? I was planning on ordering the Vida/Dice software and trying this process. Thanks in advance for any advice.
xHeart
A weak battery prevents ECM from resetting if there is an error code. My experience, a fully charged battery is needed for VIDA/DiCE to communicate without missing signals, hence calling stored instruction "cut off fuel". ETM and AP communication is interrupted due to error code NOT being ERASED -- failed power down procedure.
You can try attaching trickle charger to the battery, and let it charge overnight. AND then try the power down procedure. But it will be a guess work without VIDA/DiCE.
A normal drive cycle is recommended after the RESET for ETM and AP to relearn.
Ftknox1301
thank you very much for the feedback I do currently have the battery on a trickle charger and we'll take it off tomorrow to see what type of results I get. I will most likely be ordering the software sometime next week and at that point hopefully we'll be able to remedy this issue.xHeart wrote: 16 Jan 2020, 10:32 A weak battery prevents ECM from resetting if there is an error code. My experience, a fully charged battery is needed for VIDA/DiCE to communicate without missing signals, hence calling stored instruction "cut off fuel". ETM and AP communication is interrupted due to error code NOT being ERASED -- failed power down procedure.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
2002 XC70 does not have Magnetti Marelli ETM, it uses the Bosch electric throttle. The adaptation for that unit can be commanded with VIDA or you turn ignition on without starting engine and wait for about 50 seconds and you'll hear the throttle get cycled twice by ECM to learn the fully open and fully closed TPS signal values.
2002 bosch turbo 5 cyl and 6 cyl engines got the bosch units except for the C70 models which were delayed till 2003. The Denso 5 cylinder non turbo engines switched to Denso electric throttles for 2003.
Ftknox1301
Thank you for the advice but unfortunately this did not solve my issue. I charged my battery for 2 days and did like you said turn the key to the on position waited for about 90 seconds then repeated that process two more times just to be certain. I should have though software in a few weeks hopefully I will learn more from the codes being stored in the ECM as to what the issue is.jimmy57 wrote: 16 Jan 2020, 16:06 2002 XC70 does not have Magnetti Marelli ETM, it uses the Bosch electric throttle. The adaptation for that unit can be commanded with VIDA or you turn ignition on without starting engine and wait for about 50 seconds and you'll hear the throttle get cycled twice by ECM to learn the fully open and fully closed TPS signal values.
Is it possible that the throttle pedal sensor is now faulty? I may wind up having to get one from the salvage yard but I don't like just throwing parts at a problem unless I'm certain.
A 1 amp trickle charger for 2 days will restore about 30% of your battery power
Put on on a10 amp charger all day.
precopster
- Year and Model: Lots
- Been thanked: 128 times
You really need to read the car with a high end scanner or Vida/Dice. Rule of thumb with Volvos is they don't give accurate fault codes to low end scanners and the ELM327 adapters, though a ELM327 can usually clear 95% of codes on Volvos.
I seriously doubt a pedal sensor as they have an extremely low percentage of failure.
- 18 Replies
- 45750 Views
Last post by roywetzel
- 708 Views
Last post by jwetering
- 800 Views
Last post by Euro_Hobbs
- 4493 Views
Last post by jadnhm
- 5125 Views
Last post by Raindog92
