Welcome to the world's #1 Volvo forum!
Volvo Fixes & Advice since 2001.
Thread Repair of S70 Mechanical Belt Tensioner Bolt Hole. Helicoil, Time Sert, Form A Thread?
Has thanked: 567 times
Been thanked: 1603 times
Re: Thread Repair of S70 Mechanical Belt Tensioner Bolt Hole. Helicoil, Time Sert, Form A Thread?
About 3 hours to lower / raise the engine
Driveshafts pulled
Subframe dropped
Lower from top with the fender brace- type engine sling. Nice because it keeps the engine close to alignment so it’s easier to put back in.
Things to contemplate replacing
Sub frame bushings , and bolts ( mandatory)
Engine mounts
Tie rod ends
Steering rack boots
Lower control arms
Oil pan and pickup orings
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Year and Model: 2001 V70
Has thanked: 187 times
Been thanked: 237 times
Post by volvolugnut »
To keep your hole drilled square you can use a drill guide plate. This is a thick (1 to 2 inch) steel plate with an accurate sized hole prepared on a good drill press to be precision drilled square with the faces. This guide plate is attached with bolts or other means to the base metal to hold the drill bit square while preparing for the Timesert thread insert. Drill slowly to prevent the drill from following the old hole. It may help to use several drill sizes (and guide plate holes) to work up to final diameter. This also would work for another Helicoil. This will be tedious and difficult to get the hole back square, but it can be done. It will help that the block is aluminum.
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
