From the original owner 300k miles. Have kept it going, running great till now. Lots of routine maintenance through the years, a few problems.
Symptoms began with sudden misfires. Multiple misfire codes were read.
First checked fuel pressure which was 38 approx. psi running roughly. Pulled fuel rail and checked injectors all clean.
Today used a spark plug light on # 3 and #4 and no spark showed. Used ohm meter on the coil and it indicates 1 ohm on primaries and 8k ohms on secondary which is as manual indicates ok.
What is next? Cam sensor or other place?
1998 S70 non-turbo cranks but not starting Topic is solved
- 861 Views
Last post by jeringo
- 32 Replies
- 4932 Views
Last post by MadeInJapan
- 18 Replies
- 10393 Views
Last post by Ozark Lee
- 953 Views
Last post by seattle850
- 768 Views
Last post by 93Regina
