My lift gate was going up, but not staying up, it would slowly go back down, or come down quickly if I pressed the button.
I replaced the passenger side gas strut, no luck. I replaced the $300 hydraulic strut, and it still falls, but more slowly. I did find a bad o-ring upon removal (it started to leak when I loosened the clamp that holds the hoses in place) and I replaced that with one that came on an insert in the new strut (used to seal it).
Now, it still falls, but more slowly, especially when it gets about 50% of the way down, it almost seems like it will stay up, but it doesn't.
I did lose some fluid during the change-over of old to new struts, and I'm wondering if anyone knows how to re-fill the pump?
Since the pump is $650+, I'd rather not go replacing that yet. Any known way to repair the pump if that's the cause?
Any known procedure to refill hydraulic lift gate pump? 2010 XC60
jimmy57
- Been thanked: 322 times
Get the correct fluid, Volvo power steering fluid or Pentosin CHF 11S, and put in on of the old pump oilers. There is a plug on the pump once you get it out of the foam enclosure and you can remove it and put nozzle from pump oiler and fill that way.
- 2994 Views
Last post by MoVolvos
- 14 Replies
- 2115 Views
Last post by MotorTheresa
- 2105 Views
Last post by chrism
- 925 Views
Last post by ggleavitt
- 923 Views
Last post by misha
